12-28-2006, 15:20 | #1 (permalink) |
Major Poster Join Date: Sep 2005 Location: MX-KEY is the BEST NOKIA TOOL. Age: 49
Member: 179612 Status: Offline Thanks Meter: 15 | 1110 hang at nokia logo |
The Following 3 Users Say Thank You to ardanzx For This Useful Post: |
06-27-2007, 07:59 | #3 (permalink) |
Major Poster Join Date: Dec 2006 Location: jaipur Age: 37
Member: 412881 Status: Offline Thanks Meter: 4 | this probs related to hardware plzz rehoot flash and upp(cpu) then check battry connector , resold battrry connector may be this probs. related to battrry connectors. |
The Following User Says Thank You to wasim2006 For This Useful Post: |
07-09-2007, 04:28 | #8 (permalink) | |
Freak Poster Join Date: May 2006 Location: www.zeeqmobiles.com
Member: 275597 Status: Offline Thanks Meter: 13 | Quote:
if it is not ok then full erase the phone, flash it, and write pm Regards, www.zeeqmobiles.com | |
The Following User Says Thank You to zeeqsystems For This Useful Post: |
07-09-2007, 07:05 | #9 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | its a software problem but maximum time i found that in this situation that i heat the board from the front side by removing dome keypad the set becomes ok... |
The Following User Says Thank You to yashtel For This Useful Post: |
07-21-2008, 13:12 | #11 (permalink) |
Freak Poster Join Date: Jul 2007 Location: "From gods own Country" Age: 39
Member: 549532 Status: Offline Sonork: 100.1585325 Thanks Meter: 35 | br in my xperiencein 99 % of set will ok after flashing if set is not ok after flashing then the last solution is change upp(cpu). post result |
The Following User Says Thank You to munnachikku For This Useful Post: |
07-21-2008, 15:20 | #13 (permalink) |
Freak Poster Join Date: Nov 2007 Location: karachi,pakistan Age: 40
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | rehot the flash and upp is your problem is 100% ok |
The Following User Says Thank You to jadoon_jadoon For This Useful Post: |
Nokia 1100 Hang at Nokia Logo | murtaza_nns | Nokia Hardware & Hardware Repair | 18 | 03-05-2011 05:42 |
n95 dual sim hang at NOKIA N SERIES logo | eljhay | Infinity-Box | 4 | 04-11-2008 10:21 |
Nokia 1110 & 1600 Restart At nokia Logo | Aazib jhon | Nokia Hardware & Hardware Repair | 4 | 01-01-2008 14:44 |
n93 hangs at nokia logo when sim is inserted but without sim,works normally | GOODNESS | Nokia Hardware & Hardware Repair | 3 | 07-22-2007 17:41 |
