11-29-2008, 14:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 1110 i 12 1200 display light no need coil/trans/led/res/pf 1000000% Solution No cut any point AND Specially dont forget to say thanks |
The Following 28 Users Say Thank You to /\/\A/\/| For This Useful Post: |
11-29-2008, 17:50 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | not is good if have test this solution |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
11-30-2008, 07:11 | #4 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 446881 Status: Offline Thanks Meter: 707 | Brothers your problem is 100% solved here. Just check these links. Nokia Nokia 1200-08 Lcd Display Lights Problem Mobile Repairing Picture Help |
05-11-2009, 09:45 | #7 (permalink) |
No Life Poster Join Date: Jul 2006 Location: jambuser (sarod)_swaziland_uk Age: 40
Member: 317494 Status: Offline Sonork: 1000.1984 Thanks Meter: 187 | do u know how to work transister?????????????????????? i tell u transister work use 4 light switch off or on like switch so u need to transister may be check with transister dont remove |
05-11-2009, 11:57 | #9 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Quote:
regards | |
The Following User Says Thank You to GSM Deals For This Useful Post: |
06-17-2009, 17:47 | #11 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629694 Status: Offline Thanks Meter: 50 | why again and again fake solutions. bro lcd and keypad lights r in serial and it need more power to glow. only ic can produce tht much. ur solution just do 4v thts vbatt. close this thread admin |
11-08-2009, 03:08 | #12 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: INDIA THE HEAVEN Age: 43
Member: 890328 Status: Offline Thanks Meter: 50 | Server not found Quote:
please dont waste the valuable time agan | |
11-08-2009, 05:11 | #13 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | thanks to post but first check this solution if the set consume battery then no need to use this here in the forum lot of light solutions |
1200 light solution No need coil resistor transistor led's and ic 100% solution | /\/\A/\/| | Nokia Hardware & Hardware Repair | 15 | 02-26-2011 06:31 |
nokia 1200 display light | m.t.media | Nokia Hardware & Hardware Repair | 2 | 01-20-2010 18:30 |
1110.12.i.1200 10000% light solution no need ic/coil/transistor/ressistances/pf/ just | /\/\A/\/| | Nokia Hardware & Hardware Repair | 21 | 12-23-2009 10:29 |
n70 display ok but display light no work ? | chamak-liton | Nokia Hardware & Hardware Repair | 2 | 06-20-2009 16:53 |
Nokia 1200 Display Light | jkniji | Nokia Hardware & Hardware Repair | 6 | 07-01-2008 19:04 |
