Old 12-22-2005, 11:06   #1 (permalink)
CellWorm's Avatar
Member: 146067
Thanks Meter: 76
1110 Local Mode
i have nokia 1110, whanever i insert the battery, it show the local mode on screen
can somebody help me to solve this problem
The Following User Says Thank You to CellWorm For This Useful Post:
Old 12-22-2005, 11:38   #2 (permalink)
samirsana's Avatar
Member: 77845
Thanks Meter: 348
this problem is bsi conecteur batteri
Old 12-22-2005, 15:00   #3 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
your battery middle pin is connected to the right hand pin somewhere in circuit...
Old 12-22-2005, 16:07   #4 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
bsi line short checke middle pin battary conecteur if their any stone remove it or change battry conecteur
Old 12-22-2005, 21:02   #5 (permalink)
CellWorm's Avatar
Member: 146067
Thanks Meter: 76
i have remove thermistor [stone] and change battery connector but stil local mode.
Old 12-22-2005, 21:07   #6 (permalink)
Softway's Avatar
Member: 143889
Sonork: 100.1584685
Thanks Meter: 341
leave the mainboard under 100w bulb for 30mins. maybe ur problem will be solved
dont know about urs but i was lucky. hehe
Old 07-16-2006, 01:15   #7 (permalink)
Member: 192892
1110 local mode solution with pic please
Old 07-16-2006, 03:45   #8 (permalink)
Member: 108720
Thanks Meter: 66
Remove R2013 good work
Old 08-02-2006, 20:57   #9 (permalink)
Member: 238322
Thanks Meter: 34
LOVEtoALL
first of all give attention that the 1110, 1600 and 6030 has same scheme. use search i also have this problem and solve by picture help in this forum dont be hesitate or shy always try ur best ok
Old 08-05-2006, 10:51   #10 (permalink)
1amigo's Avatar
Member: 23587
Thanks Meter: 63
Which one is correct ? Remove R2013 or R2005. I have tried removing R2205 and it has worked. Has anyone tested removing R2013 ? Please post the result here of removing R2013.
Who knows, both solutions may be working or one solution works in some cases and the other works in other cases ?
It would be interesting to know the results, so please post who have tried removing R2013.
And what is here on this thread ?
http://forum.gsmhosting.com/vbb/show...11#post1821011
Please discuss it out here all active members on this two threads !
Regards and Respect to All.
File Type: jpg 1110_1600_6030 local mode 100% sol.JPG (190.6 KB, 2079 views)
The Following 5 Users Say Thank You to 1amigo For This Useful Post:
Old 03-25-2007, 12:15   #11 (permalink)
Member: 475307
Nice Shot. I Done It. its a 100000000% Ok Tested ...
Thanks A Lot. 0321-6536757
Old 03-25-2007, 12:33   #12 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
good work 1 amigo .....
Old 03-25-2007, 13:05   #13 (permalink)
Member: 334575
prof
pls i have 3510i which when you insert battery it will enter TES MODE can any one help?.
Old 04-14-2007, 15:52   #14 (permalink)
Crazy Poster
Member: 159000
Thanks Meter: 13
dear i have nokia 1110. its dead . i flash it with latest ver.but after flash its not showing local mode.
Old 04-16-2007, 07:31   #15 (permalink)
Member: 350571
Thanks Meter: 920
remove the companents show in this picture
The Following 2 Users Say Thank You to sree krishna For This Useful Post:
1110 local mode tayseer Nokia Hardware & Hardware Repair 0 06-04-2008 03:34
I Need Solution For Nk 1110 Local Mode ..::khaled::.. Nokia Hardware & Hardware Repair 5 09-18-2007 19:02
1110 Local mode amol_sm Nokia Hardware & Hardware Repair 5 10-14-2006 12:18
1110 local mode ashok_kumar459 Nokia Digital Core Technology 4 ( DCT-4 ) 6 07-11-2006 18:52
1110 local mode Yashaka Nokia Hardware & Hardware Repair 11 07-11-2006 09:33
Page generated in 0.24322 seconds with 10 queries
