1110 not charging solution hello every 1 plz help me out for nokia 1110 not charging solution |
hello everyone,can you give me some solutions about this not charging problem. |
hello every 1 can you help me about this problem for nokia 1110 not charging. |
search old posts....................... |
2 Attachment(s) Quote:
when u connect charger if there is nothing then its COIL or FUSE , if appears Not Charging then its DIODE |
1110 Quote:
when fuse or diode are open , the cell give no msg , if these are good and prob is others , in case of other prob cell give msg not charging .i think he should removed R2013 , his prob will be solved |
mostly the charging diode has short , in case the cell give no msg |
r2013 solves many sets,try it first br,Basta |
remove R2013 100% ok |
Regards SL3 UNLOCKERS FREE |
sdjffjkcbnvgjkfklgfklmgmklfh |
