03-31-2007, 15:28 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | 1110,2310,1600,1112,bad speaker sound hardware solution Quote:
first change one more time speaker new or current workink 100% tested speaker , after change the speaker your problem not solve, FOLLOW THIS SOLUTION | |
The Following 2 Users Say Thank You to sree krishna For This Useful Post: |
03-31-2007, 17:51 | #9 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | We Need To Understand Some Things As Far As Ear Pieces And Ringers Are Concerned. If A Phone Has Both Ringer And Ear Piece Separately, The Ringer Will Give A Reading Of About 7-9 Ohms While The Ear Piece Will Give Around 35 Ohms At Most. However, If The Sound System Is Such That Both Hearing And Ringing Are Done By One Component As Is The Case In Phones Like 1110, 1600, 1112, And Others The Resistance Will Be Low Giving Around 7-9 Ohms. Now, If You Made A Mistake Of Replacing This Type Of Ringer/ear Piece Combined With 35 Ohms Which Is Designed To Work As Hearing Component Only, You May Have The Like Of The Problem You Mentioned Here. So, Get A 7-9 Ohms Speaker For Replacement Before Trying To Go A Little Bit High-tech. |
The Following User Says Thank You to ABUU YUUNUS For This Useful Post: |
W610i bad quality of sound | Mafiasz | Sony Ericsson Hardware Repair | 0 | 06-23-2009 17:24 |
T610: mic OK but sound is bad, what IC operate with sound? | PSG | Sony Ericsson Hardware Repair | 0 | 06-13-2007 17:44 |
Need azalis 238 flash very very BAD | jerrel | Philips | 4 | 07-28-2003 08:58 |
