04-24-2007, 19:33 | #3 (permalink) |
Crazy Poster Join Date: Jul 2006 Location: Goa India
Member: 310194 Status: Offline Sonork: techsolutiongoa Thanks Meter: 5 | a few tips my friend on charging problems 1. check ur charger 2. sometimes it is the battery that is faulty so change battery and see, also if the battery voltage shows less than 1 volt the battery will not charge 3. check the components like fuse, coils and diode in the charging circuit 4. connect the charger and check for the voltage on the battery points it must be around 3.5- 4 volts only then ur battery will charge try these tips and post reply tc |
1110i charging way | HICHEM TIGS | Nokia Hardware & Hardware Repair | 2 | 09-13-2009 01:03 |
1110i STRANGE PROBLEM AFTER FLASH | quasim0438 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 04-10-2007 12:05 |
1112 and 1110i menu problems after unlock | dadustar | Universalbox | 2 | 12-08-2006 00:23 |
