Old 05-19-2007, 15:23   #1 (permalink)
Member: 494756
1110i insert sim card
I have 1110i that droped in water i have serviced it but now when i put my simcard in set, receive "insert sim" error.what should i do?
The Following User Says Thank You to badmasiha For This Useful Post:
Old 05-20-2007, 19:01   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
have you change sim esd filter ? it is located near sim socket
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 05-21-2007, 05:31   #3 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
open ur mobile phone and check the charging jack wash it dry it it and put back now reassemble it it will be ok no need to tak more headeck dont chang the sim ic or etc
Regaurds
Asghar Hussain
The Following 2 Users Say Thank You to mobilecitycbk For This Useful Post:
Old 05-21-2007, 06:21   #4 (permalink)
Crazy Poster
Member: 505765
Thanks Meter: 13
you just remove the sim ic and do the jumpering as given inthe picture
it will work.............. sure
regards
rajeesh.k.p
The Following 3 Users Say Thank You to kprajeesh4u For This Useful Post:
Old 05-21-2007, 08:39   #5 (permalink)
hafizjee's Avatar
Member: 234653
Thanks Meter: 83
Thumbs up 1110 ,1600.1112,2310,insert sim solution
try this image
Hafiz Mobiles
The Following 2 Users Say Thank You to hafizjee For This Useful Post:
Old 05-21-2007, 08:51   #6 (permalink)
Member: 244357
Thanks Meter: 70
may be it is sim ic problem or charging connector problem.first change charging connector, then clean pcb contact,where the connection of the charging connector touching, if it's same change sim ic carefully or make jumpers.
Old 05-22-2007, 07:24   #7 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
Change sim ic.............................................
Old 05-22-2007, 08:11   #8 (permalink)
Member: 494756
thnx dear friends
problem wolved with changing sim ic
Old 05-22-2007, 09:05   #9 (permalink)
Member: 438350
please send me RM64 (6030) pm
Old 05-22-2007, 09:10   #10 (permalink)
Member: 438350
dear sir my phone 3650 if unlock it will on. not in battery please help me
Old 05-22-2007, 09:33   #11 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
brother 6030 is not rm 64 its rm 74
here is ur pm..
Old 05-22-2007, 20:08   #12 (permalink)
Member: 68831
nooooooooots 6030 is not rm 64 its rm 74
Old 10-30-2007, 07:41   #13 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
dear sir i have a 1600 insertsim card i do shot sim ic i do flash too nd short the charging jeck but they still same problem plz helpme
Old 10-31-2007, 20:52   #14 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
brother just check the battry connector's middle point that may be bended or may be not touching the middle point of battry even if this happen set show insert sim
Old 10-31-2007, 21:54   #15 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
Hi , at first you will check pcb back side and wash there because some time there come water and dirty that’s way some time concelebrated the system . if not done insert sim then you can try jumper way solved and replaces ic .one think what I advice you .I share my knowledge but chooses is your …..
1110-Insert sim card, jumper solution is ok but for me the best replaces IC…you need that IC you can find easily any 1100, 2300, 2600, 3220, so many sets sim ic is same. Now chooses is your,
good luck………..
...::: Nokia 1110,1110i,1600,2310 New insert sim card Solution :::... sujan1050 Nokia Hardware & Hardware Repair 1 12-10-2008 20:02
Nokia 3120 dual sim : sim card rejected or insert sim card msg??? adrian17w Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-30-2005 18:25
3310 Insert Sim card with sim card in side uwenk98 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-25-2003 17:28
Z7e insert sim card with sim card inox Sony 4 09-14-2003 19:34
Page generated in 0.25302 seconds with 11 queries
