Old 03-04-2008, 18:01   #1 (permalink)
Member: 698048
Thanks Meter: 9
1110i light all time
please help me
i have 1110i whith light open all time and auto charging problems
Old 03-04-2008, 19:30   #2 (permalink)
Member: 698048
Thanks Meter: 9
please help me urgent
Old 03-04-2008, 19:42   #3 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
Thumbs down
change trangister near the led.
Old 03-04-2008, 19:51   #4 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
Thumbs down
Originally Posted by talebufs View Post
please help me
light all time is solved following the picture.
Old 03-05-2008, 03:14   #5 (permalink)
Registered User
Member: 557494
Thanks Meter: 14
change power ic it will solve ur problem bro...
Old 03-05-2008, 07:36   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" both guys r right,if first one doesnt work then prob is in uem, keep it up boyz"
Old 03-05-2008, 08:59   #7 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
change the light i.c. it will be ok bro.
Old 03-05-2008, 09:55   #8 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
CHANGE transister its the most solution for that problem
SP
Old 03-05-2008, 16:03   #9 (permalink)
Member: 698048
Thanks Meter: 9
thank you
i tested this solution but not work for me
and i have the auto charging problem in this mobile
Old 03-05-2008, 20:49   #10 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
thank you
if you set is water damage . then try to clean first and check base voltage of switching transistor , is there switching or not ?its called KDL pin form UEM
Auto charging clean charging connector PCB ,change charging base too. there will be some short due to rust by water damage .
RASHID
Old 03-06-2008, 02:52   #11 (permalink)
sezief's Avatar
Member: 119200
Thanks Meter: 56
the solution by the picture working 100% tested by me many times
Old 03-06-2008, 03:10   #12 (permalink)
Member: 685445
Thanks Meter: 10
mate just post first the history of that unit for better solution
Old 03-06-2008, 11:02   #13 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
if open resister (r2409)near switching transistor(v2401) also light wont off 1,transistor 2,resistor,3,volt @ transistor collector pin if not check control signal from UEM & its track all ok its no hope coz it must with UEM problem how to change molding uem i also dont know pls who know that way pls post here
SP forever.............................
Old 03-06-2008, 11:17   #14 (permalink)
Member: 608803
Thanks Meter: 13
Angry be real
all you need is be real and follow ur instinct
Old 03-06-2008, 17:11   #15 (permalink)
Member: 698048
Thanks Meter: 9
thank you all i will try your solutions and i will tell you
Nokia n95 8gb camera flash lights all the time krefcik2 Nokia Base Band 5 ( BB-5 ) 1 10-11-2009 18:33
Is S60 unlock work becouse I try 5 times and all time ERROR ON SERVER SIDE wgmmmx Universalbox 22 12-24-2008 06:48
1110,1600,1112,1110i,, LIGHT SOLUTION......... punitdodiya Nokia Hardware & Hardware Repair 15 11-26-2008 08:13
1110i light SOLUTION akkaiyaselvam Nokia Hardware & Hardware Repair 5 07-22-2008 10:59
1110i light problem khalidsain Nokia Hardware & Hardware Repair 2 10-30-2007 09:38
Page generated in 0.22846 seconds with 10 queries
