10-20-2007, 23:50 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | hi,flash with new vertion re write pm file if not done then flash only ppm............................... if not done hit with table lump 10 minite then flash again i think your problem will be solved...... good luck.............................................. .................................................. ................... |
10-21-2007, 01:10 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | first chk with device that set on or not,if yes than clean the whole circuit and give good heat,than chk wat will happen,also chk with charger that it charge or not. |
10-22-2007, 08:03 | #6 (permalink) |
Freak Poster Join Date: May 2006 Location: Ajmer, India Age: 36
Member: 280646 Status: Offline Thanks Meter: 45 | 1112 connect it to ufs with/without sim and with/without display and click at normal mode in ui options. if normal mode ok there then check ur display, disp conn. and its print. gud luk. keep sharing ur experience. |
2310 flash ok but cant power on | Jayrus | Nokia Hardware & Hardware Repair | 3 | 01-13-2008 16:48 |
n80 flash ok but cant power on | davi yong | Nokia Hardware & Hardware Repair | 2 | 08-16-2007 04:40 |
3610 flashing ok still cant power on | gama_cell99 | Nokia Hardware & Hardware Repair | 7 | 03-08-2005 20:12 |
8310 dead flashing ok but cant power on | mobilemafia | Nokia Hardware & Hardware Repair | 13 | 06-11-2003 23:00 |
