Old 05-31-2007, 14:16   #1 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
1112 LCD Light..
hi all..
i have a 1112 that lcd light are no working.. pls help me... phone crash the wall...
The Following User Says Thank You to LoveLess For This Useful Post:
Old 05-31-2007, 16:07   #2 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
hi just check coil, backlight glass ic, and a transistor below keypad.
if all these r ok check display and display connector
WBR
The Following User Says Thank You to bhuvanele For This Useful Post:
Old 05-31-2007, 16:18   #3 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
WBR
Old 05-31-2007, 16:44   #4 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
initially check the track open from lcd connector to lcd driver ic component if it is ok than check coil beside the light ic, if it also ok than finally change the light ic
Old 06-01-2007, 05:53   #5 (permalink)
Member: 244357
Thanks Meter: 70
dear, first cleane the pcd near keypad where led related parts.
or change led ic and check coil,transistor ,lcd and lcd connector.
otherwise tell me peticular problem.
Old 06-01-2007, 06:01   #6 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
Thanks Meter: 161
The Following User Says Thank You to Euan For This Useful Post:
Old 10-03-2011, 10:24   #7 (permalink)
nathan111284's Avatar
Member: 1370010
Thanks Meter: 57
solutions not work....
still no light bro....
Old 10-03-2011, 10:40   #8 (permalink)
lucky2010's Avatar
Member: 1322713
Sonork: 100.1663786
Thanks Meter: 254
Dear chek this links.............
http://forum.gsmhosting.com/vbb/f148...ht-ic-1296553/
http://forum.gsmhosting.com/vbb/f148...-work-1223140/
Old 10-03-2011, 12:38   #9 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
http://4.bp.********.com/-nBPkCOE_Rl...2BSolution.jpg
Old 10-03-2011, 12:39   #10 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
1112 1600 new led salusan
[IMG]http://4.bp.********.com/-nBPkCOE_Rl4/ToiXJSNAYZI/AAAAAAAADT4/xm1p8DPpxfM/s400/Nokia%2B1110%252C%2B1110i%252C%2B1112%252C%2B1600% 252C%2B2310%252C%2B2610%252C%2B2626%252C%2B6030%2B Light%2BSolution.jpg[/IMG]
1110 1110i 1112 LCD + KeyPad LIGHT SOLUTION imran zafar Nokia Hardware & Hardware Repair 27 01-18-2016 08:05
1110,1112,1600 etc. LCD light solution abdul4gsm Nokia Hardware & Hardware Repair 47 06-19-2012 07:53
1110 1110i 1112 1600 lcd light solution new discover Shantobhai Nokia Hardware & Hardware Repair 44 09-20-2010 04:36
1110 1110i 1112 LCD + KeyPad LIGHT SOLUTION gsm junction Nokia Hardware & Hardware Repair 0 03-15-2010 11:11
1112 no light on keypad and lcd solved!!! sigma xi Nokia Hardware & Hardware Repair 8 04-13-2009 11:29
Page generated in 0.29252 seconds with 10 queries
