Old 07-08-2007, 09:45   #1 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
1112 strange LCD problem
1112 no display
I checked with new display
I checked all the LCD tracks all fine
I changed new display connector
Still same status
Old 07-08-2007, 09:51   #2 (permalink)
Member: 285779
Thanks Meter: 49
posible with sw prob
Old 07-09-2007, 06:03   #3 (permalink)
Member: 139388
Thanks Meter: 98
This is not a software problem.Phone is getting on and off,Incoming calls also no problem.Only no display.
Anyhow i flashed the phone too.No result same status
Old 07-09-2007, 06:29   #4 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
check your connection through reverse technology...............
Old 07-09-2007, 11:48   #5 (permalink)
Member: 139388
Thanks Meter: 98
I can't understand wht u r saying,Explain more
Old 07-09-2007, 11:57   #6 (permalink)
guedes666's Avatar
Member: 108180
Sonork: 100.106866
Thanks Meter: 381
try to flash the phone with last SW version i think 6.41 if not works, try this CNT file and post the result
B.R.
guedes666
Old 07-09-2007, 12:12   #7 (permalink)
wasee8882's Avatar
Member: 207488
Thanks Meter: 5
yeh brother its software problem ..
Old 07-11-2007, 06:43   #8 (permalink)
Member: 139388
Thanks Meter: 98
I tried all the way in the software.
Made full erase and Flashed with V5.54 and V6.01 no use
Tried with erase file also
Tried 3 different Pm files no use(MHZ pm,RepairPM,etc.)
Tried in UFS,JAF and universal box
It was 100% hardware problem.Have any guide?
Old 09-17-2007, 14:13   #9 (permalink)
lolan's Avatar
Member: 181862
Thanks Meter: 38
pls explain............
pls explain what is reverse technology..............
Old 09-17-2007, 14:32   #10 (permalink)
lolan's Avatar
Member: 181862
Thanks Meter: 38
hello brother,
Originally Posted by celluniversal View Post
1112 no display
Still same status
did u fix this........
canwe chat now.
my id is [email protected] or [email protected]
Old 10-18-2007, 09:48   #11 (permalink)
Member: 600376
Thanks Meter: 16
Thumbs down 1112
1112 no display
Still same status
when U power on the mobile Lcd light is on?
Old 10-18-2007, 12:30   #12 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
1112 no display
Still same status
brthr change the three resistence near the cpu ..these resistence are between the track... if then ur problem not solve then reball or change cpu...
Old 10-18-2007, 13:13   #13 (permalink)
Muneer Ahmed's Avatar
Member: 60500
Thanks Meter: 2
It is a software problem. Try to flash the phone when the lcd is attached, if it does not work then try to flash the phone without LCD and then attach the same or any other LCD....try and post the result if it works or not?
Muneer Ahmed
Old 01-02-2008, 15:19   #14 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
Smile 1112 lcd track
Connect the phone with UFS and then click info if you see LCD : Unknown
its mean your LCD track is broken re check all the tracks if all tracks is ok then its UPP fault try to rehot the UPP carefully
Old 01-02-2008, 20:26   #15 (permalink)
Member: 669218
Thanks Meter: 11
first flash the set with 6.9 ver. or 6.4 ver. then change the resistancs one by one i hope ur problem wil solve
Nokia 1112 Strange Keypad problem..Experts Help me. rk_grover77 Nokia Hardware & Hardware Repair 16 06-27-2013 09:37
Strange LCD Problem - K750i wonkypants Sony Ericsson Hardware Repair 3 12-01-2006 12:01
K750i HELP - Strange LCD Problem - Please Read shahzad9 Sony Ericsson Hardware Repair 0 12-31-2005 18:29
GD87 Strange LCD problem Konnect 2K Panasonic 2 12-19-2003 21:21
Very strange LCD problem....... Abe Nokia Hardware & Hardware Repair 7 06-17-2002 04:24
Page generated in 0.23062 seconds with 10 queries
