1200,1208,1650 blue screen 100000000000000% solution tested 1200,1208,1650 blue screen 100000000000000% solution tested only blue light stand outgoing incoming not ok complete flashing ui but set same condition so change display connector self test with hwk see lcd unknown this is connector problem tested with 11 set |
oh realy bt i cant understand is lcd conector is short ther 4 thiz problm is came? |
try one 100%................... |
tested by me 100% ok |
i have Nokia 1200 with water dameg dispaly is yellow after few secon plz help me |
thanks 1000 percent working i make out board conector pin .... Thanks bro 7 set ok now |
i have nokia 2626 after few secends the display turn into blue light after few secend i had changed lcd connector done full flash then too the problem is not solving plz help mee |
bro just rehot cpu only |
i have 1208 today i changed its charging jack(every thing was ok before this),when i switched it on then it said"local mode"what is this,then it started charging,hands free,data cable at mobi mb also was ok.but after a few time when i again restarted it it showed again local mode.on connceting charger it said"not charging"after this my set is completly dead,no on,no msg........nothing .plz help me ..what is problem... |
i'll try later... thx bro |
help me in blue screen heloo brother plz help me and more deals so easy in blue screen i have 5 sets 1200,1208 same condisation |
hi mate. check the solders of your charging pin. there may be shortings in it. |
