01-10-2011, 02:23 | #44 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Nigeria
Member: 620382 Status: Offline Thanks Meter: 18 | My bro. This can also make your work faster. 1. Test the 2 keypad LED with multimeter- if bad, change it. 2. Check the flex and the LCD connector- if bad, change it. 3. Use multimeter to check bat +ve to the LED coil- if break, jumper it. 4. Use multimeter to check continuity between the 2 keypad LED- If break, jumper it. I wish you good luck. If you like my post, please press the thanks botton! |
Nokia 1200 & 1208 Light Problem 100% Tested Solution | mahmud | Nokia Hardware & Hardware Repair | 13 | 10-19-2013 17:41 |
1200,1208 light solution 100%%%.new | Dooha_Bd | Nokia Base Band 5 ( BB-5 ) | 11 | 01-30-2011 14:37 |
1200-1208 light solution | reaj | Nokia Hardware & Hardware Repair | 0 | 09-13-2009 01:06 |
need 1200/1208 light solution | malikasim | Nokia Hardware & Hardware Repair | 5 | 02-14-2009 10:57 |
