Old 07-02-2008, 11:13   #1 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
1200
i have n 1200 can not make or receive call i had full flashed it with latest version but still same .....when i make call from it, it can not make any call just calling....... and when it receive call there is only ringtone and no other option like answer it only displays silence any one plz help.......i am confused with it what should i do......
Old 07-02-2008, 11:49   #2 (permalink)
mehedi.h.j's Avatar
Member: 324042
Sonork: 100.1578276
Thanks Meter: 3,504
Full erase ........ then flash with jaff.
Old 07-02-2008, 11:53   #3 (permalink)
janki_amreli's Avatar
Member: 324208
Thanks Meter: 35
full erese & flash jaf % wright good pm fime u r problam is sole
Old 07-16-2008, 06:52   #4 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
i had full erased and flashed it many times but still same any more solution...
Old 07-16-2008, 07:08   #5 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
this is hardwear problem need to replace upp
Old 07-17-2008, 19:24   #6 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
R u sure this is the hardware problem and after replacing upp set works fine .....
Old 07-17-2008, 19:43   #7 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
yaa it is 90% hardwere.
Old 07-18-2008, 06:29   #8 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
what should i do to solve this problem...i had reheated the upp also any one pleeeez help
Old 07-18-2008, 06:43   #9 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
i think there is no solution ......i had returned it back to coustomer
Old 07-18-2008, 06:50   #10 (permalink)
Crazy Poster
Member: 652810
Thanks Meter: 10
i hope itwas cpu problems
Old 08-24-2008, 22:08   #11 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
only make factory setting with jaf
Old 08-25-2008, 11:25   #12 (permalink)
Member: 841178
Sonork: jadoon
plz help me for nokia 1200 light ic or ic way
Old 08-25-2008, 11:51   #13 (permalink)
Member: 747244
1200 failed to start, after full erase, then full flash set failed to startup.....with jaf
Old 08-25-2008, 13:17   #14 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
nokia 1100 off after 20 sec
hi nokia 1100 turn off after 20 sec i rehot his mcu and cpu and problem not soulve i will flash it but not ok help me plz plz
Old 08-25-2008, 14:24   #15 (permalink)
gulam khadir's Avatar
Member: 800786
Thanks Meter: 48
check battery connector or replace 99% ur problem will b solvad
Play mp3 ring tones in nokia 1200 khanmobiles0003 Nokia Base Band 5 ( BB-5 ) 1 01-31-2011 20:09
kh 1200 helppppp iphone 3gs Octopus LG/Octoplus LG 2 04-01-2010 07:36
Play mp3 ring tones in nokia 1200,1208 khanmobiles0003 Nokia Digital Core Technology 4 ( DCT-4 ) 0 03-29-2010 18:50
Need to convert nokia 1200 rh99 to nokia 1200 rh 100 krich70 Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-23-2009 00:47
Page generated in 0.27310 seconds with 9 queries
