Old 08-24-2009, 06:04   #1 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 451
Arrow 1200 Contents Package Extracting Failed
when flasing in hwk "Contents Package Extracting Failed" error or with UB flashing ok, but no network found. when m chek with hwk it's ok, but get info, no info, because m write pm file with hwk or how to write pm file with UB help me it's urgent
Old 08-24-2009, 06:39   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,374
Bro.1st try erase flash...& agin flash...
1st solution not work ,..........
rehot flash ic & agin flash........
result post here............
Old 08-24-2009, 06:45   #3 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 714
just use easy cable your prob solve 1000000000
{ahmadge}
The Following User Says Thank You to ahmadge For This Useful Post:
Old 08-24-2009, 08:08   #4 (permalink)
Sony_computers's Avatar
Member: 570022
Thanks Meter: 64
Replace Flash ic and repair IMEI, 100% tested......
Old 08-24-2009, 08:43   #5 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,338
reball flash ic then try..........
Old 08-24-2009, 08:47   #6 (permalink)
Member: 1098446
Thanks Meter: 5
yes
rehot flash ic
problem will be solved
Old 08-24-2009, 08:49   #7 (permalink)
dabing's Avatar
Member: 857401
Sonork: 1596086
Thanks Meter: 126
flash with jaf
if same problem reball flash ic. flash again, write pm unlock, problem solve
Old 08-24-2009, 08:50   #8 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
Originally Posted by safdar_75 View Post
yes
rehot flash ic
this is the solution
The Following User Says Thank You to cel_phon For This Useful Post:
Old 08-24-2009, 10:00   #9 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 08-24-2009, 10:17   #10 (permalink)
kenecee's Avatar
Member: 772242
Sonork: 100.1640371
Thanks Meter: 43
this is mostly flash ic problem
Old 08-25-2009, 04:23   #11 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 451
not work same problem
any other solutions
The Following User Says Thank You to sr8787 For This Useful Post:
nokia 1200 Contents Package Extracting Failed: Process Failed, Repowering Mobile romey_singh2 HWK 39 08-03-2017 14:04
1200 Contents Package Extracting Failed sr8787 Nokia Hardware & Hardware Repair 8 09-28-2010 14:10
Contents Package Extracting Failed DonaldDuck69 Twisterflasher 32 08-06-2010 08:49
1200 Contents Package Extracting Failed sr8787 Nokia Hardware & Hardware Repair 1 08-20-2009 10:23
Page generated in 0.33813 seconds with 8 queries
