09-02-2009, 18:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: MUMBAI
Member: 583454 Status: Offline Thanks Meter: 80 | 1200 dead flashing log posted In UFS3 HWK 2.0.9.0 ERROR 1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032 Algorithm: u3_st_i.fia, Ver: 4.79.0 Algorithm Ok, MSID: 8404D2CA04DF33A7F56494276A Decoded MSID: 3E4EBAE9-00578FB0-A8000000 Encoded FAID: EC213082-165D5836-4D007E96 IMAGE: rh99_05.230 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01 Area2: 0x01010000-0x013AFFFF Erased, Time: 01:03 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01000000:08 Process Failed, Repowering Mobile In MXKEY giving ERROR Processing file: rh99_05.230 ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00578FB0:2984DA60 Programming MCU ... rh99_05.230: [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 1.062 s Area [01010000-013AFFFF] erased in 59.735 s Area [013B0000-013EFFFF] erased in 4.281 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Error while programming [1000000] at 0x00000014, Result: 0872 Flashing terminated with error(s) in 1 min 30.937 s RX Buffer: 087 In JAF giving ERROR Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Last edited by waqarN70; 09-02-2009 at 19:00. |
The Following User Says Thank You to waqarN70 For This Useful Post: |
09-02-2009, 19:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro.rehot or reball flash ic..& agin flash...... result post here........... |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
04-20-2010, 17:41 | #3 (permalink) |
Freak Poster Join Date: Oct 2006 Location: love in your heart
Member: 373527 Status: Offline Thanks Meter: 68 | same probem with me i have 1209 1st error i reball cpu than 1st boot ok here is log by ufs 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.1.0.1] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 8437AD8498008D4842C3325DCE Decoded MSID: 3E4EBAE9-00D100D7-A8000000 Encoded FAID: 56544CF7-6F1BDAE0-FCC99708 IMAGE: rh105_05.710 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:40 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01000000:08 |
1600 dead while flashing log posted here plz help | broken_rules | Nokia Hardware & Hardware Repair | 4 | 02-25-2009 19:58 |
1600 while flashing log posted here plz help | broken_rules | Nokia Hardware & Hardware Repair | 1 | 02-25-2009 16:59 |
N73 water dead ,flash log | sajidmirza | Nokia Hardware & Hardware Repair | 1 | 02-07-2008 07:45 |
