Old 03-14-2008, 12:11   #1 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
1200 Flashing Error
I HAVE FLASH 1200 JAF PHONE IS (CONTACT SERVICE) IM FACKTORY SETTING SAME PROBLUM I HAVE FLASH THEN ERROR THIS TYPE
JAF version 1.98.46
Detected PKEY: 900113EB
Card life counter: 99.17%
P-key nokia module version 01.00
Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B0, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 3.44
01-09-07
RH-99
(c) NMP
HW version:
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: P06w45.v36
LCD version: WIN:MYKS:01
ST7506
PPM version: V 3.44
01-09-07
RH-99
(c) NMP
MG
ADSP SW version: V 3.44\n01-09-07\nRH-99\n(c) NMP\nmg
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359554014833670
IMEI spare to net: 3A 95 55 04 41 38 63 07
IMEI SV to net: 33 95 55 04 41 38 63 27 F8
Master Code: 4255740507
Failed reading simlock data...
Phone type: RH-99, Software version: 3.44, Language Pack: MG
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.110
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.11ad
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai4.11ad
Languages in ppm: English,French,German,Turkish
Done!
Backing up PM Field 208 as RPL...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_04.110
Booting phone...
MCU ID: 0x0000
This MCU ID is not supported in chosen flash file...
Error booting phone...
Old 03-14-2008, 12:24   #2 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
check your cable if your cable ok
tick in the settings SKIP MCUID
Old 03-14-2008, 12:53   #3 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 201
u flash latest verson donot work change cable . donot worak u mast be flash mt-box.
Old 03-14-2008, 13:02   #4 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
check your cable
and use jaf for the flash
Old 03-14-2008, 14:02   #5 (permalink)
Member: 476739
Thanks Meter: 507
cabel is ok
i have all ready cheking cabel this cabel other mob sukshfull flash this mob read info ok flass error
Old 05-30-2008, 05:41   #6 (permalink)
Member: 773115
Sonork: masumpdb
i have same problem but when i change cable then work . s o it is cable fault, so pls check cable.
Old 05-30-2008, 05:48   #7 (permalink)
Member: 427333
i think is power ic spoil
Old 05-30-2008, 06:00   #8 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Is is sure it is cable problem.
But u say phone is can't detect.
OK Try to do self test & post here self test result.
If all is OK (Phone is on by CS)
Post result.
Old 06-16-2008, 07:17   #9 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
thanks for sharing...........................
N96 Weird Flashing error javakiller MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 10-10-2010 11:55
nokia 1200 flashing error ameho0102 Nokia Hardware & Hardware Repair 19 05-24-2010 05:17
1650 flash error nilesh_patel717 Nokia Hardware & Hardware Repair 3 03-29-2010 14:03
1200 Flash Error Plz Help Me sonojee Nokia Hardware & Hardware Repair 2 07-29-2009 17:36
need help 1200 flash write error brain00000 Nokia Hardware & Hardware Repair 2 04-13-2009 08:31
Page generated in 0.18505 seconds with 9 queries
