11-28-2008, 06:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: country of five rivers
Member: 395477 Status: Offline Sonork: 100.1602978 Thanks Meter: 140 | 1200 got only light after change jeck what is problam i flashed it ,flashed ok but no solution |
The Following User Says Thank You to singhdeep For This Useful Post: |
11-28-2008, 11:09 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | is phone working ? means incoming outgoing ok , if ok change flex cable or change lcd or resold lcd connector on pcb & check , if not ok remove the ui connector & check |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
11-28-2008, 11:14 | #3 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
possible fault shorted due to disalign... | |
The Following User Says Thank You to venuno For This Useful Post: |
11-28-2008, 12:24 | #6 (permalink) |
Member: 395477 Status: Offline Sonork: 100.1602978 Thanks Meter: 140 | thanx but i also replaced lcd and flex with working phone but nothing now i remove that chargingjek and post result thanx for reply |
12-02-2008, 06:07 | #10 (permalink) |
Member: 395477 Status: Offline Sonork: 100.1602978 Thanks Meter: 140 | ok now i removed the charging jeck but problam is same there is noliqued in ic but only light on lcd,phone dont work,no incoming no outgoing plz help me .. costomer angry |
01-06-2009, 08:55 | #14 (permalink) |
Member: 395477 Status: Offline Sonork: 100.1602978 Thanks Meter: 140 | i have one more 1200 liqued damage,after service now only light,flex ok,lcd ok,call incoming and out going ok but nothing on lcd cant flash |
01-06-2009, 08:56 | #15 (permalink) |
1200,108 only light... | masudtel | J.A.F. By Jafsupport.com | 8 | 10-24-2008 21:33 |
1110 no light after changing keypad crystal | kopotan bahr | Nokia Hardware & Hardware Repair | 4 | 07-11-2008 13:59 |
e700 no light after change flat cable | hightechsquare | Samsung Hardware Repair | 18 | 03-13-2007 22:29 |
No back light after changing lcd | nickemac | Samsung Hardware Repair | 4 | 06-11-2006 11:10 |
BF3 only light after reviving with bekosbrothers soft?? | infogsm | BF, BG, TH, BHx Series | 7 | 06-30-2003 17:03 |
