04-02-2007, 09:40 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Age: 36
Member: 344810 Status: Offline Thanks Meter: 52 | 1100 not charging soultion (its new) if u checked all avaliable soul then do this.. 1: get a nokia charging spare wire. ( u can get easily from electronics parts shop in 10 rupees in pak) 2: get new universel charger 3:now open ur unversel charger and put nokia charger wire on output of universal charger.and u can remove batt holder on universal charger(i hope u understand if not ask) 4: open ur 1100 or 2300 , remove fuse,coil,diode and cap,4 parts under batt conecter, 5: now jump wires from charging base to batt conetor, two charging point on batt conecter from behind, 6: safe ur conections with tape or something ...and also put tape on pcb where charging base charging points touch. 7: close ur set and power on ur mobile, nw plug ur new nokia Anti not charging charger in mobile and u will see charging bar on ur charger.. it is 100% safe and i done obve 22 phones from this soul...... just u have to be carefull with conections ,, u can use ur phone while charging too...... try and post result .. i have nt try this solution yet (i quoted this post) !!ALL CREDITS GOES TO SHAHJEE!! |
04-02-2007, 19:47 | #3 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
Just think (and keep in mind) what will happen .... when you are "off-road" WITHOUT YOUR "MODIFYED" CHARGER ..... and some1 (who don't know about your "fixed" phone) put your mobile on NORMAL Nokia charger ... Can you try and post here the results ... BR | |
04-03-2007, 05:18 | #4 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
hello this is old wrong solution, all members please dont try this solution because if you try this solution, within two days pf ic will gone this is my real expereance, and i will give one advice to all members and friends, without service knowladge please dont give any solution to other, otherways first try ur self then post here, hi members and friends please dont mistake me thank you | |
10-01-2007, 21:32 | #9 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 56
Member: 58375 Status: Offline Thanks Meter: 12 | stupid solution and nice wy to kill ur fone , bcoz when u supply direct voltage from charger to +ve batt these voltages go into uem , charger are mostly adjusted on 5-7 volts while battery carries 3.6v so more the voltages less the fone life , guaranteed |
1100 not charging | gbada | Nokia Hardware & Hardware Repair | 35 | 07-08-2012 14:48 |
1100 not charging and auto charging | gsmsikar | Nokia Hardware & Hardware Repair | 11 | 03-23-2009 23:30 |
1100 not charging solution? | etcelfon | Nokia Hardware & Hardware Repair | 4 | 07-30-2008 16:20 |
3530 not charging soultion | jignesh_1000 | Nokia Hardware & Hardware Repair | 0 | 06-25-2005 08:37 |
1100 not charging | jaaja | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 03-07-2005 04:55 |
