Old 01-19-2009, 04:59   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
1200 Left,Right,7 and Dial keys not working
Hello, i get Nokia 1200, with keypad fault.
its Left key, right key Dial button and 7 button is not working.
i changed its kypad chip two times but still have problem.
any friend has its solution?
share with me.
Thanx in Advance.
The Following 2 Users Say Thank You to Adil Mobiles For This Useful Post:
Old 01-19-2009, 05:41   #2 (permalink)
Member: 626855
Thanks Meter: 14
sir try 2 rehot upp and keypad ic............. 100% pro slove
The Following User Says Thank You to lavkey For This Useful Post:
Old 01-19-2009, 06:00   #3 (permalink)
Member: 797497
Thanks Meter: 3
cleen with good ctc cleen key pad ic point on board then a new key pad ic
Old 01-19-2009, 06:37   #4 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
first chang key pad ic
then
rehot or rebol upp
The Following User Says Thank You to metro2mobile For This Useful Post:
Old 01-19-2009, 07:39   #5 (permalink)
Member: 902952
Thanks Meter: 8
then
rehot or rebol upp
agree with you.........
The Following User Says Thank You to Ceedor For This Useful Post:
Old 01-19-2009, 07:46   #6 (permalink)
samirov-gsm's Avatar
Member: 759168
Thanks Meter: 12,866
change ic keypad and good luck
The Following 2 Users Say Thank You to samirov-gsm For This Useful Post:
Old 01-19-2009, 08:05   #7 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Thanks Meter: 180
Only one soluaion change key paid ic. many time i will try this 100% ok........................
Old 01-21-2009, 04:27   #8 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
i have changed it 2 keypad Chips but still giving problem. keypad tracks r well. but
Old 01-21-2009, 04:36   #9 (permalink)
Member: 513210
Thanks Meter: 110
reballs Upp Sir, its UPp problem...
Old 01-21-2009, 06:50   #10 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
Chang inner Panel And Rehot Key Pad IC 100% Tested.
The Following User Says Thank You to suraj9860607689 For This Useful Post:
Old 04-07-2010, 07:38   #11 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
i hv changed the new ic the problem is 100% solved regards
The Following User Says Thank You to shahid555 For This Useful Post:
Old 04-14-2013, 10:27   #12 (permalink)
Member: 1407021
Sonork: 7239
Thumbs down
thanksssssssssssssssssssss
Old 04-15-2013, 09:39   #13 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
share with me.
Thanx in Advance.
bro no need to change keypad ic for any one serial not work
try this sure soluyion-
http://i48.tinypic.com/6td5vk.jpg
Old 04-15-2013, 12:07   #14 (permalink)
Member: 1722956
Thanks Meter: 305
Originally Posted by fukuan View Post
what man?
a person is in a trouble and needyour help.
instead of helping him you advertise .
help if you can othewise keep silent.
nokia 7210c 7,8,9 key not work speed infotech Nokia Hardware & Hardware Repair 22 09-04-2013 11:41
7310c 7,8,9 key not working solution here! biniesh_08 Nokia Hardware & Hardware Repair 12 07-30-2013 18:31
2600 classic up down left right ,send and end button not working plz help asif_ae Nokia Hardware & Hardware Repair 7 06-18-2009 22:49
left ,right up and down keys hugues Samsung Hardware Repair 0 11-20-2007 15:51
D800 left and clear key not working david laborator Samsung Hardware Repair 2 11-02-2007 18:54
Page generated in 0.20377 seconds with 9 queries
