11-06-2008, 19:12 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 38
Member: 751223 Status: Offline Sonork: mobilecenter88 Thanks Meter: 538 | 1200 light solution complete here mohammed anis Last edited by mohammed-anis; 11-06-2008 at 19:21. |
The Following 72 Users Say Thank You to mohammed-anis For This Useful Post: |
11-06-2008, 19:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | " bro use schema itz my suggestion to u & reply sensibly, first pic from left side u hav written check both parts tell me wt we hav to check & wt will be the result, second pic change this part wt is the relation between that part & light section & third pic 3.7v cut from which place it is cut & wt we hav to do, i will reply back soon i read urs next post" |
The Following 4 Users Say Thank You to mobilespeed For This Useful Post: |
11-06-2008, 19:55 | #3 (permalink) |
Member: 751223 Status: Offline Sonork: mobilecenter88 Thanks Meter: 538 | 3.7 v connected with (+) battery connector to coil short this point with battery led is glow so your coil is ok with 6.7 v your ic is ok |
The Following 31 Users Say Thank You to mohammed-anis For This Useful Post: |
11-06-2008, 20:11 | #4 (permalink) |
Member: 706300 Status: Offline Thanks Meter: 147 | " firstly i do congratulate u for correcting the pics to some extent, do u mean to know whether coil is ok or not we hav to first connect vbat to coil & then connect the coil to led if led glows, it will indicate coil is ok & u mean c 2400 gives 6.7v it means ic is ok, it would be the interesting topic" |
The Following 5 Users Say Thank You to mobilespeed For This Useful Post: |
11-07-2008, 07:07 | #5 (permalink) | |
Member: 706300 Status: Offline Thanks Meter: 147 | Originally Posted by mohammed-anis 3.7 v connected with (+) battery connector to coil short this point with battery led is glow so your coil is ok with 6.7 v your ic is ok Quote:
The Following 7 Users Say Thank You to mobilespeed For This Useful Post: |
11-08-2008, 09:42 | #7 (permalink) | |
Member: 751223 Status: Offline Sonork: mobilecenter88 Thanks Meter: 538 | Quote:
i have not more discussion this topic because my english are poor sorry | |
The Following 2 Users Say Thank You to mohammed-anis For This Useful Post: |
11-05-2009, 08:42 | #9 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1004257 Status: Offline Sonork: [email protected] Thanks Meter: 14 | hello sir ji 1200 ka light waireng new sir plzzzzzzzzzzz |
1200 light solution No need coil resistor transistor led's and ic 100% solution | /\/\A/\/| | Nokia Hardware & Hardware Repair | 15 | 02-26-2011 06:31 |
1200 light solution 10000000000000000%ok | rubel_chk007 | Nokia Hardware & Hardware Repair | 7 | 04-04-2010 21:39 |
NOKIA 1200 LIGHT SOLUTION New Mathod | lucky121 | Nokia Hardware & Hardware Repair | 0 | 10-07-2009 17:31 |
1200 light solution 100%ok............................................ ............... | rubel_chk007 | Nokia Hardware & Hardware Repair | 3 | 08-28-2009 08:53 |
Best 1600.1100,1110,1200 light solution 2009 | francis10gh | Nokia Hardware & Hardware Repair | 4 | 03-07-2009 00:08 |
