Old 01-11-2009, 16:48   #1 (permalink)
Member: 405273
Thanks Meter: 34
1200 not on with battery
Plz plz any body help me my Nokia 1200 with power supply ok ON
but with battery it not power ON
I changed batt terminal & chek BSI Line its ok but same
plz help me
Old 01-11-2009, 16:50   #2 (permalink)
..:::Gsm india:::..'s Avatar
Member: 380464
Thanks Meter: 141
reball uem your problem is salve 100000000%
Old 01-11-2009, 18:32   #3 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
plz check voltage on on-off switch is OK or not
Old 01-11-2009, 19:23   #4 (permalink)
Member: 675717
Thanks Meter: 125
With power supply set on/off ok so no problem in power button.Rehot or reball UEM.
Old 01-11-2009, 20:30   #5 (permalink)
Registered User
Member: 427297
Thanks Meter: 3
it works 100000%
just change charging bass phn will b on with battery.its guaranted and tested.try this then mail me 4 [email protected]
Old 01-11-2009, 20:38   #6 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
chang bettery concter if same try this one
The Following User Says Thank You to GSMTURBO For This Useful Post:
Old 01-11-2009, 20:58   #7 (permalink)
Member: 160624
bro simply short the bsi & gnd terminal at battery terminal .it will be on 100%.
thx
Old 01-12-2009, 08:55   #8 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
re hot and rebol uem your fone is on
Old 01-12-2009, 09:11   #9 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
http://forum.gsmhosting.com/vbb/atta...5&d=1228589055
try this
The Following User Says Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-12-2009, 10:21   #10 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
just rehot uem or reball it...
your phone will fine and completely can be on..
Old 01-12-2009, 15:02   #11 (permalink)
Member: 405273
Thanks Meter: 34
i also short the bsi & gnd terminal but phone not on with battrey
Old 01-12-2009, 15:02   #12 (permalink)
laddimobile's Avatar
Member: 672494
Thanks Meter: 109
1200 soloution
first u do soft the soft is ok and ur set is no on and change the flex then set again no power on u change the display ok
iam shure ur set is work properly & if ur soft not corect then u chek shorting .i think ur set is short ok chek it and tell me again.
Old 10-05-2011, 12:54   #13 (permalink)
Member: 366714
Thanks Meter: 21
You are correct my friend. I also tested many times.
1200 not working with battery but with shok aparat it is work Elshad Ngage Nokia Hardware & Hardware Repair 5 08-25-2009 09:34
6600 power not on with battery plz help me amanhalwara Nokia Hardware & Hardware Repair 2 01-13-2008 19:33
6230 flash ok but not on with battery zeerik Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-26-2007 09:54
6600 Not On With Battery Pl Help amanhalwara Nokia Hardware & Hardware Repair 1 10-27-2007 13:44
1100 not on with battery zeerik Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-26-2007 13:28
Page generated in 0.20484 seconds with 10 queries
