1200 ui setting and normal mode ok but no power on with battery. 1200 ui setting and normal mode ok but no power on with battery. im very confuse with a nokia 1200 handset.. 1200 ui setting and normal mode ok but no power on with battery.. that hand set powering on with box cable in normal mode, but with battery no response. i tryed this kind of jumpers http://forum.gsmhosting.com/vbb/atta...9&d=1210518969 http://i176.photobucket.com/albums/w...8NOPOWER-1.gif but same result - no power on with battery.. |
hope your problem will be solve. |
Bro Remove 4 legs not charg local mode resistor and then check......... |
yes Bro Remove 4 legs not charg local mode resistor and then check......... |
thanks... removing 4 leg local mode resistor is 10000000% successful solution.. |
no work :confused:its no work to me also change rasister but not power on to batry |
