09-06-2009, 06:55 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 507911 Status: Offline Thanks Meter: 22 | 1202 , 1661 unlock 100% ! just change the upp with version 2292 from 1200 or 1208 because upp version 2293 not suport unlock yet ! tested 100% but high risk and high cost too ! |
09-07-2009, 15:57 | #6 (permalink) | |
Member: 507911 Status: Offline Thanks Meter: 22 | see this ! Quote:
1st Boot: Ok, DCT4, UPP: 2292 [Rh-112] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 847DD0E25E23121214FC3A2884 Decoded MSID: 3E4EBAE9-00C1870E-A8000000 Encoded FAID: A42A0515-8D2C9231-A0902935 IMAGE: rh112_003.000 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:30 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:18 IMAGE: rh1120_nai03.00mr Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:00 Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:28 1st Boot: Ok, DCT4, UPP: 2292 [Rh-112] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 847DD0E25E23121214FC3A2884 Decoded MSID: 3E4EBAE9-00C1870E-A8000000 Encoded FAID: A42A0515-8D2C9231-A0902935 IMAGE: rh112_003.00mr Area1: 0x01240000-0x0124FFFF Erased, Time: 00:00 Area2: 0x01250000-0x0137FFFF Erased, Time: 00:09 PPM Flashing Completed, Time: 00:07 Flashing Completed, Rebooting Mobile IMEI: 356396-02-359099-7, ASIC: 11 FILE: rh112_003.000 1st Boot: Ok, DCT4, UPP: 2292 [Rh-112] [2.0.9.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 847DD0E25E23121214FC3A2884 Decoded MSID: 3E4EBAE9-00C1870E-A8000000 Encoded FAID: A42A0515-8D2C9231-A0902935 Area1: 0x011E0000-0x0121FFFF Erased, Time: 00:01 PAT Flashing Completed, Time: 00:01 IMEI: 356396-02-359099-7, ASIC: 11 SimLocks Initialized (Patch Ok), Time: 00:00 SimLocks Initialized, Time: 04:16 UI Defaults Ok, Time: 00:02 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:06 nb: not show up sharing only ! | |
The Following User Says Thank You to juwana_pati For This Useful Post: |
1202, 1661 MobiMb 100% tested Download here | AsiaGSM™ | Nokia Multimedia | 36 | 05-27-2010 16:38 |
MX-Key Team Pls Add 1202,1661 Unlock ... | ronygsm123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-04-2010 11:55 |
1202, 1661 unlock supported or not... | adnanskyland | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 11-14-2009 07:45 |
