Old 03-09-2010, 05:44   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
1202 compatible light / sim card / buzzer ic ???
can i use 1600 light / sim card / buzzer ic for nokia 1202?
The Following 4 Users Say Thank You to hooi76 For This Useful Post:
Old 03-09-2010, 07:11   #2 (permalink)
mmmfaruk's Avatar
Member: 1114923
Thanks Meter: 224
yes brother
thuse ic is same with 1600 and 1202,1661
but kepad ic is not same
i replace light / sim card / buzzer ic from 1202 to 1600 for many tome and successed
for more
plz contect
[email protected]
The Following 2 Users Say Thank You to mmmfaruk For This Useful Post:
Old 03-10-2010, 01:30   #3 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
thank you, then which ic is compatible for keypad?
The Following 2 Users Say Thank You to hooi76 For This Useful Post:
Old 03-10-2010, 01:47   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,229
u can use normal nokia ic
The Following 2 Users Say Thank You to HUM For This Useful Post:
Old 03-10-2010, 01:47   #5 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
Light IC , key pad ic, buzzer IC are same as 1600, but sim IC same as 3110c
someone said that key pad IC is not same , its absolutely wrong ,its lack of knowledge. key pad IC same as 1600-1200-6030-1110-1112-7610-6670 etc. its has 24 pin ESD , check my pis
Rashid Ahmed Nadeem
The Following 12 Users Say Thank You to r a nadeem For This Useful Post:
Old 03-10-2010, 01:50   #6 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
Originally Posted by mmmfaruk View Post
yes brother
for more
plz contect
[email protected]
Dear how much knowledge you have ? don't misguide to any person . if you not sure ,
Rashid Ahmed Nadeem
Old 03-10-2010, 02:05   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,229
sir rashid please give me solution of 1202 no ringer,no speaker,no network and restart
all these problems at the same time
prints are ok
already flash with all versions
reball upp
reball uem and flash ic
still no success
Old 03-10-2010, 22:26   #8 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
prints are ok
reball upp
still no success
Dear HUM ,
did you check short at battery terminals , some time when set consume voltage , cause such prob . second 1202 is single layer PCB , and its ways under shield joint , when we remove shield , we lost some prints. they damage due to carelessness ,
i had repair more then 50 sets
Rashid Ahmed Nadeem
Old 03-10-2010, 22:46   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,229
respected sir when these sets comes to me its very fresh no shield removed
sir i chk shortage but there is no shortage on terminals
sir u r my senior and i really respect u,can u please tell me how u repair this problem
waiting for reply
Old 03-11-2010, 02:29   #10 (permalink)
mmmfaruk's Avatar
Member: 1114923
Thanks Meter: 224
Rashid Ahmed Nadeem
sorry
kepad ic is same but sim ic is not so
i mistake to turn them during write
The Following User Says Thank You to mmmfaruk For This Useful Post:
Old 03-11-2010, 22:11   #11 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
waiting for reply
Dear HUM ,
Thanks for regards ,
i want to know that when it restart. which position .whats its initial
position, after flashing it happened , after removing something , or you received set already in this state . plz give me some info about it
Rashid Ahmed Nadeem
Old 03-11-2010, 22:27   #12 (permalink)
Member: 975117
Sonork: rivacomcell center
Thanks Meter: 45
Dear HUM ,
Rashid Ahmed Nadeem
DEAR MR NADEEM
help mr nadeem ...
i need PICTURE SMPS JUMPER FOR N90 ..CAN HELP ME??
PHONE IS WHITE SCREEN AND HANG
THANKS BEFORE
Old 03-11-2010, 23:27   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,229
Dear HUM ,
i want to know that when it restart. which position .whats its initial position, after flashing it happened , after removing something , or you received set already in this state . plz give me some info about it
Rashid Ahmed Nadeem
one set recieve in signal problem when manually search set will restart,it also restart when i put on table or some where in standby mode
in this set these actions are taken:
reball upp
reball uem
i m not changing pa bcoz i face this problem in 1208 (no signal and when search manually set will restart) and i solved by reballing or changing upp so thats why doubtful between upp and pa
one more set recieve in problem of hang,but here i mention one thing problem solved by clean the pcb and lamping,but in uem area i found some dry soldering so i rehot uem and due to dryness of uem and pcb balls set gone dead
i reball uem and set is power on again.................ringer ok,earpiece ok,signal ok i chk with ufone sim it also ok than i i put this set in my draw,after one day when customer comes to recieve his set,there is no ringer,no earpiece,no network and restart problem
i try flashing but no success
write pm but no result
chk selftest
it show same selftest as compare to ok set selftest
also rehot flash ic
but same
5030 no network and restart on manual searching
change pa
rehot upp
rehot flash ic
rehot uem
change all parts related to signal
there is one thing when remove filter restart problem gone but no network still same
already try flashing
write pm
change filter but same
Old 03-12-2010, 22:38   #14 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
Originally Posted by Arief Wibowo View Post
DEAR MR NADEEM
help mr nadeem ...
THANKS BEFORE
remove marked IC and make jumper like in pic
Rashid Ahmed Nadeem
The Following 3 Users Say Thank You to r a nadeem For This Useful Post:
Old 03-12-2010, 23:03   #15 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,168
Dear HUM
(one set receive in signal problem when manually search set will restart,it also restart when i put on table or some where in standby mode
reball upp
reball uem
i m not changing pa bcoz i face this problem in 1208 (no signal and when search manually set will restart) and i solved by reballing or changing upp so thats why doubtful between upp and pa)
IN this prob fault goes to PA
chk selftest
also rehot flash ic
but same
Change UEM again , some rust has been create prob. under UEM
(5030 no network and restart on manual searching
change pa
rehot upp
rehot flash ic
rehot uem
write pm
change filter but same)
in this case change crystal ,
mostly in
1202-1203 1661-1662 -5030 restart , crystal create this prob , i have faced these prob ,
Rashid Ahmed Nadeem
The Following User Says Thank You to r a nadeem For This Useful Post:
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 3 06-09-2015 09:56
6300 sim card registration failed!!! ..::khaled::.. Nokia Hardware & Hardware Repair 16 07-19-2011 17:00
w200 compatible light ic ratan_deb Sony Ericsson Hardware Repair 0 11-08-2009 08:15
7610 compatible buzzer ic ratan_deb Nokia Hardware & Hardware Repair 1 11-07-2009 10:15
Is the K750 buzzer ic compatible with K610 or K618? hooi76 Sony Ericsson Hardware Repair 4 02-09-2009 13:10
Page generated in 0.50875 seconds with 9 queries
