06-12-2010, 13:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::1202 contact service all locks open::.. all locks open here is info Version Info: MCU SW version: V 04.03 29-06-09 RH-112 (c) Nokia HW version: 1002 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w22_U LCD version: WIN:SERI:8a NT7542 PPM version: V 04.03 29-06-09 RH-112 (c) Nokia EL ADSP SW version: p V 04.03\n29-06-09\nRH-112\n(c) NMP\nel Product Info: Production serial number: DRR326860 Product code: 0562271 Module code: 0203762 Basic production code: 0558505 Serial Numbers: IMEI plain: 358251035686390 IMEI spare to net: 3A 85 52 01 53 86 36 09 IMEI SV to net: 33 85 52 01 53 86 36 19 F9 Other Info: CS type : GSM/DCS1800 BSI: 4.6 KOhm Imei net: 35825103568639 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN here is selftest Phone Type: RH-112 SW version: V 04.03 29-06-09 RH-112 (c) Nokia ID Test name Startup Result 46 UEM_CBUS_IF Y passed 15 SLEEP_X_LOOP Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y !failed ! 13 SIM_IO_CTRL_LOOP Y !failed ! 39 WARRANTY Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY Y passed 43 LCD Y passed 41 FLASH_CHECKSUM N passed 30 RF_CHIP_ID N !failed ! 52 KASUMI N passed |
06-23-2010, 05:46 | #7 (permalink) |
Junior Member Join Date: Apr 2009 Location: mingora Age: 38
Member: 1005393 Status: Offline Thanks Meter: 4 | same problem here is the logs i tried it on mxkey Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\35826503507680_BACK.r pl). Processing file: rh112_003.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004614A2:2984DA60 Area [01000000-0100FFFF] erased in 1.343 s Area [01010000-013AFFFF] erased in 1 min 13.046 s Area [013B0000-013EFFFF] erased in 5.297 s Area [017C0000-017EFFFF] erased in 0.485 s Area [01FC0000-01FEFFFF] erased in 0.391 s Flash programming ... Programming completed in 27.109 s File Processed in 1 min 59.250 s Processing file: rh1120_nai03.00qa_demo as CNT [DCT4,DCT4 ALGORITHM] size: 102.37 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004614A2:2984DA60 Area [01380000-013AFFFF] erased in 3.891 s Flash programming ... Programming completed in 1.422 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.219 s File Processed in 23.422 s Processing file: rh112_003.00ac as PPM [DCT4,DCT4 ALGORITHM] size: 992.47 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004614A2:2984DA60 Area [01240000-0124FFFF] erased in 1.281 s Area [01250000-0137FFFF] erased in 23.578 s Flash programming ... Programming completed in 10.594 s File Processed in 46.453 s Flashing completed in 3 min 18.625 s After Flash Processing ... Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35826503507680-8 Product Code: 0562271 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AC Language Pack: - not available. Imei net: 35826503507680 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 32.812 s |
06-23-2010, 06:56 | #9 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 45
Member: 351924 Status: Offline Thanks Meter: 12,467 | 13 SIM_IO_CTRL_LOOP Y !failed ! remove sim ic then check after remove sim ic phone show this same problem cs ?check power ic,power ic controlled by CTRL,DATA,CLOCK Bus post result |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
06-23-2010, 07:14 | #11 (permalink) |
No Life Poster Join Date: Aug 2009 Location: faisalabad PAKISTAN
Member: 1092450 Status: Offline Thanks Meter: 196 | RapidShare: 1-CLICK Web hosting - Easy Filehosting some time this problem plz chack it |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
