Old 03-02-2009, 16:11   #1 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
1202 Contact Service .............help
1202 contact service
i already tried full Erase
Flash
unlock but same problem
i dont have Good pm
need Good pm beter if tested
The Following 8 Users Say Thank You to lahoot For This Useful Post:
Old 03-03-2009, 18:00   #2 (permalink)
mutunmobile's Avatar
Member: 570193
Thanks Meter: 31
brother try to full flah and unlock good luck
The Following 3 Users Say Thank You to mutunmobile For This Useful Post:
Old 06-20-2009, 12:15   #3 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
Flash
i dont have Good pm
i am waiting yet for any other solution
The Following User Says Thank You to lahoot For This Useful Post:
Old 06-20-2009, 13:21   #4 (permalink)
Member: 645970
Thanks Meter: 157
DEAR, try to flash with same version or unlock by jaf, if not sucess try to unlock by U.B, you will sucess 100%................. HERE IS PM FILE LINK : http://www.usaupload.net/d/1fa9uhcxvyl
The Following 2 Users Say Thank You to ashish mobile For This Useful Post:
Old 06-20-2009, 13:35   #5 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
hello first full erase then write full flash and write pm then fetory settings then unlock use 3.00 version all will be ok
The Following User Says Thank You to goherabbas For This Useful Post:
Old 06-20-2009, 13:41   #6 (permalink)
Member: 406299
Sonork: none
Thanks Meter: 280
if you full erase your phone....
then contact service no solution yet...
correct me if im wrong...
The Following User Says Thank You to JMJ ALBERT For This Useful Post:
Old 06-20-2009, 13:48   #7 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,174
Thumbs up 1202 contact service
..::Brother to first erase and then flash letest version and unlock and write good pm so your problem solved::..
The Following 3 Users Say Thank You to RIZWANJAT For This Useful Post:
Old 06-20-2009, 13:58   #8 (permalink)
.::LUQMAN::.'s Avatar
Member: 413053
Sonork: 100.114351
Thanks Meter: 458
Read Information if Your Phone Sp Date Corrupt Then W8 For New Update Fix This Issue
Not Yet...
The Following 4 Users Say Thank You to .::LUQMAN::. For This Useful Post:
Old 06-20-2009, 15:08   #9 (permalink)
Crazy Poster
Member: 505765
Thanks Meter: 13
contact service
contact service may occur also due to faulty display strip /display /display connector . first remove the display flux from reverse side of the borad and connect fresh display directly there .....
make sure the display connector on the borad is ok......
post the result ......
i have the same problem with many set 50% solved by this ......
gud luck
rajeesh.k.p
The Following 6 Users Say Thank You to kprajeesh4u For This Useful Post:
Old 06-20-2009, 20:38   #10 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
brother try to full flah and unlock good pm tri this........
The Following 2 Users Say Thank You to chamak-liton For This Useful Post:
Old 07-05-2009, 01:21   #11 (permalink)
Member: 295762
Thanks Meter: 130
any box can fixed this problem? used jaf and micro can't solved for unlock this phone
The Following 3 Users Say Thank You to dedeyk For This Useful Post:
Old 07-11-2009, 12:00   #12 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
i already tried full erase
flash
i dont have good pm
need good pm beter if tested
only full flash with 3.0 version .then after flashing no unlock no ui no full factory only flash .
The Following User Says Thank You to sajidashraf For This Useful Post:
Old 07-11-2009, 13:54   #13 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
i think there is no solution for 1202 contact service
but u can unlock country code
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 07-23-2009, 12:27   #14 (permalink)
*shohel*'s Avatar
Member: 537394
Thanks Meter: 19
1202 can't unlock jaf box.1202 contact service any solution pls .............................?
The Following User Says Thank You to *shohel* For This Useful Post:
Old 07-23-2009, 12:57   #15 (permalink)
*shohel*'s Avatar
Member: 537394
Thanks Meter: 19
N70 Phone Startup Failed [Archive] - GSM-Forum
nokia 6303c contact service help.............. RABIULSK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-09-2010 21:18
nokia 6303c contact service help...... RABIULSK Universalbox 5 03-30-2010 11:31
1202 contact service help need abdurrahimsagar Nokia Digital Core Technology 4 ( DCT-4 ) 4 01-15-2010 15:18
1202 contact service help need abdurrahimsagar Nokia Base Band 5 ( BB-5 ) 6 01-13-2010 20:09
Page generated in 0.19626 seconds with 9 queries
