08-08-2009, 17:10 | #16 (permalink) | |
No Life Poster Join Date: May 2007 Location: *** TUNISIA *** Age: 41
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | it's true!!! Quote:
when i resolde the display set is ok after 2 or 3 min contact service again | |
The Following 2 Users Say Thank You to usi_golden For This Useful Post: |
09-23-2009, 08:52 | #17 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Only "Unlock" is solution of Contact Service but there is no flashing box update arrived for this. Just wait for unlock support from any box lik me. ZubairArain |
05-21-2010, 08:04 | #20 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Bangladesh
Member: 1162506 Status: Offline Thanks Meter: 177 | Brother I have a 1202 contact service. I Full erase it. Then Full flash it. write good pm. and unlock with Infinity and Dct4+ unlocker. But Same. Help me Please. |
06-09-2010, 14:33 | #25 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bangladesh
Member: 885387 Status: Offline Sonork: 100.1597540 Thanks Meter: 82 | 1202 contact service 1:full erase 2:full flash v4.03 3:write good pm 4:then unlock BUS CHECK BY USE MAXKEY Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00112D70A3BDA66 ASIC type: 11 UEM Imei: 35826103331289 Flash Imei: 35826103331289 MasterCode: 2100575725 RPL saved to "C:\mobileEx\3.4\data\backup\35826103331289_BACK.r pl" Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35826103331289-9 Product Code: 0562205 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35826103331289 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN PHONE INFO BY USE MX-KEY Version Info: MCU SW version: V 03.10 21-01-09 RH-112 (c) NMP HW version: 1000 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_08w31_UPP LCD version: INLX:SERIv81 NT7542 PPM version: V 03.10 21-01-09 RH-112 (c) NMP EL ADSP SW version: p V 03.10\n21-01-09\nRH-112\n(c) NMP\nel Product Info: Production serial number: HBE135380 Product code: 0562205 Module code: 0203762 Basic production code: 0558505 Serial Numbers: IMEI warranty: 353195030331756 IMEI plain: 358261033312899 IMEI spare to net: 3A 85 62 01 33 13 82 09 IMEI SV to net: 33 85 62 01 33 13 82 19 F5 Other Info: CS type : GSM/DCS1800 BSI: 5.6 KOhm Imei net: 35826103331289 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN when try normal mode by cable then show insert sim card but when try with battery then contact service any good solution |
The Following User Says Thank You to eyasin For This Useful Post: |
06-10-2010, 10:20 | #26 (permalink) | |
Member: 1162506 Status: Offline Thanks Meter: 177 | Quote:
Brother it is hardware problem. Your phone may be water damaged. so wash the board and put it under a heater light. your problem may be solved. | |
The Following User Says Thank You to miraz20 For This Useful Post: |
06-11-2010, 15:41 | #28 (permalink) |
Junior Member Join Date: Dec 2007
Member: 644497 Status: Offline Thanks Meter: 2 | download this link to unlock DCT4 Plus RSA Unlocker test OKKKKKKK. or chang lcd |
The Following User Says Thank You to mr linkcool For This Useful Post: |
nokia 6303c contact service help.............. | RABIULSK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-09-2010 21:18 |
nokia 6303c contact service help...... | RABIULSK | Universalbox | 5 | 03-30-2010 11:31 |
1202 contact service help need | abdurrahimsagar | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 01-15-2010 15:18 |
1202 contact service help need | abdurrahimsagar | Nokia Base Band 5 ( BB-5 ) | 6 | 01-13-2010 20:09 |
