Old 07-20-2009, 21:16   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,214
..::1202 flashing error::..
nokia 1202 flashing error
here are the logs
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 00000000 <=> Flash -> not detected Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
FLASH ID1: 00210020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 3E B6 1A 23 10 03 00 C6 05 C4 01 00 22 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-112\rh112_003.100
Booting phone...
MCU ID: 0x2293
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
Flash ID is 0x00000000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: d6
Loader is ready...
MSID: 84709045A445612C8EA7620A90
MSID decoded: 3E4EBAE900F15306A8000000
FAID: E2AD153CB09CCE5C7D433EE7
Operation took 0 minutes 17 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 10 seconds...
Writing...
Permanent Data Restore FAILED!
Operation took 12 minutes 3 seconds...
Restarting MCU...
Failed! Aborting!
Old 07-21-2009, 04:16   #2 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,540
bor re-hot or re-ball flash ic,,,,,,,,,
Old 07-21-2009, 04:23   #3 (permalink)
Member: 975567
Thanks Meter: 7
try another cable mate ,
if not try to re-heat or re-work upp
or check the line ...
Old 07-21-2009, 08:38   #4 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 538
here are the logs
Getting MCU ID
MCU ID: 0x2293
Algo is ready...
Done!
Phone Restarted...
Booting phone...
MCU ID: 0x2293
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing...
Writing...
Restarting MCU...
Failed! Aborting!
do this your problem is 100% ......................cover this point and do factery setting with jaf
The Following 2 Users Say Thank You to zeerik For This Useful Post:
Old 07-21-2009, 10:09   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,214
dear its 1202
Old 07-21-2009, 12:44   #6 (permalink)
mkhan's Avatar
Member: 178659
Thanks Meter: 46
cheng the cpu your problum is 10000000% ok
..::1202 flashing and ui setting ok but no power::.. HUM Nokia Hardware & Hardware Repair 42 04-14-2013 05:55
..::6600s flashing error::..[SOLVED] HUM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 02-10-2010 08:55
..::1208 flashing error::.. HUM Nokia Hardware & Hardware Repair 6 09-02-2009 02:48
..::6280 flashing error::.. HUM Nokia Hardware & Hardware Repair 3 03-28-2009 20:52
.::v3 flash error::. rajabrotherscom Smart-Clip 3 05-20-2006 12:12
Page generated in 0.32245 seconds with 9 queries
