07-25-2009, 15:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::1202 flashing and ui setting ok but no power::.. |
The Following 4 Users Say Thank You to HUM For This Useful Post: |
07-25-2009, 22:03 | #7 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | any solution i remove system connecter but still no power bcoz system connecter is slightly water logged |
The Following User Says Thank You to HUM For This Useful Post: |
07-25-2009, 23:33 | #8 (permalink) |
Insane Poster Join Date: Apr 2006 Location: Kisii, Kenya
Member: 264203 Status: Offline Thanks Meter: 17 | brother put pinless simcard in and restart phone with softawrae jaf/ufs in normal mode. If you hear start up tone then replace lcd. If not keep flashing with latest flash. Remember to say thanks |
The Following 2 Users Say Thank You to rochris For This Useful Post: |
08-26-2009, 16:29 | #12 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Remove or chaange Ic behind system connector and remove capacitor and resistor behind the batt. conn. |
The Following User Says Thank You to baldev For This Useful Post: |
08-26-2009, 16:48 | #13 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | 1>>>dear do charging.. if its showing charging that means its power track is break.. 2>>>when u do it normal mode then display was ok? if all is ok then remove local mode resister array problem will be ok post result.. we are waiting |
The Following 2 Users Say Thank You to kapilgupta For This Useful Post: |
08-26-2009, 17:04 | #15 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Here is 100% working solution Here is your solution bro,If your power key voltage is good,Remove this component WBR, ..::MOBILES::.. |
The Following 7 Users Say Thank You to ..::MOBILES::.. For This Useful Post: |
..::nokia 1200-1208 Flashing And Ui Settings Ok But No Power Solution::.. | HUM | Nokia Hardware & Hardware Repair | 56 | 11-23-2011 09:11 |
..::1661 flashing ok but no power::.. | HUM | Nokia Hardware & Hardware Repair | 11 | 01-09-2010 12:30 |
NOKIA 6610i, FLASHING AND UI SETTING OK, STILL CONTACT SERVICE | dinoadropy | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 12-03-2009 11:28 |
please help me!! Ngage Qd flash & Ui Setting ok, normal mode failed | protek | Nokia Hardware & Hardware Repair | 2 | 09-26-2008 21:48 |
n90 flash ok ui setting ok but no power on | raknahs | Nokia Hardware & Hardware Repair | 1 | 04-07-2008 17:40 |
