04-05-2010, 14:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | 1600 dead very strange problem And phone is not going turn on with battry,can anyone give me feed back. |
04-05-2010, 14:46 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | remove the double resistence,of local mode,,,,,also check battery terminal, - 1,,,,,,if not succes,,,check upp,,and also full flash,and then unlock,,plz post result |
04-05-2010, 15:04 | #4 (permalink) |
Member: 1183572 Status: Offline Thanks Meter: 203 | 'CHECK" here is logo with jaf Getting MCU ID MCU ID: 0x2201 FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... INFO---- FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 7.02 10-12-07 RH-64 (c) NMP HW version: 0502 PCI version: UEM version: 1314 UPP version: 8705 RFIC version: 0500 DSP version: P05w06.v34 LCD version: UNKWN: IDs: 00:ff:00 PPM version: V 7.02 10-12-07 RH-64 (c) NMP MG ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nmg Production serial number: ICA627402 Product code: 0525146 Module code: 0202591 Basic production code: 0520754 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35*********** IMEI spare to net: 3A 25 62 00 21 02 18 00 IMEI SV to net: 33 25 62 00 21 02 18 40 F5 Master Code: 3425162315 Phone type: RH-64, Software version: 7.02, Language Pack: MG User code: ÿ# Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0525146 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02mg CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02mg ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Hindi,Marathi Done! |
Nokia 1600 very strange problem | celluniversal | Nokia Hardware & Hardware Repair | 6 | 09-30-2007 08:11 |
UFS3 + HWK very very strange problem ???????????? | makroud | UFS2 + UFS3-Tornadoflasher | 2 | 04-13-2006 10:14 |
M35 DEAD - Very Strange Problem! | johny3310 | x1x to x45/x50 | 11 | 06-07-2004 01:58 |
s300m very very very strange problem | mp3hot | Trident/AGERE Platform | 0 | 02-03-2004 20:29 |
Very Very Strange Problem On Be4 | Pandemonio100 | Alcatel & TCL Old Models | 1 | 06-25-2002 20:00 |
