05-17-2009, 13:16 | #1 (permalink) |
Registered User Join Date: May 2009
Member: 1026865 Status: Offline Thanks Meter: 37 | 1208 and 1209 flash files same or no but after flash the mobile is dead plz any solution |
The Following User Says Thank You to AS_ADNAN440 For This Useful Post: |
05-17-2009, 13:23 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: "I work for Good weekend"
Member: 765990 Status: Offline Sonork: 100.1582347 Thanks Meter: 207 | Yes brother are same. no difference.Do it with jaf or ub will ok no problem.With UFS3 its have some problem. |
The Following User Says Thank You to raja16sep For This Useful Post: |
05-17-2009, 13:30 | #5 (permalink) |
Member: 1026865 Status: Offline Thanks Meter: 37 | after flash log this ufs and jaf not solve this problem JAF version 1.98.63 Detected PKEY: 90010CB7 Card life counter: 95.90% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Searching for default location of ini... Checking path: \Products\RH-105\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ Scanning ini files... Checking path: \Products\RH-105\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ip CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ip ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Changing flashing settings... Checking path: \Products\RH-105\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ia CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ia ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.510 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84AEFDF0AAC72FE040EC45FACB MSID decoded: 3E4EBAE9009DE04FAA000000 FAID: 05B47BEF7746C0F3F3E94D67 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 44 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 22 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.51ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 8458DB11D3AF5900CF67914032 MSID decoded: 3E4EBAE9009DE04FA9000000 FAID: A7B48A53CA75C7F6E31E398E Operation took 0 minutes 17 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 13 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.51ia Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x74888900 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5548; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 8458DB11D3AF5900CF67914032 MSID decoded: 3E4EBAE9009DE04FA9000000 FAID: A7B48A53CA75C7F6E31E398E Operation took 0 minutes 16 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 2 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 3 minutes 1 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
05-17-2009, 14:05 | #15 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: http://labibtelecom.blogspot.c
Member: 631470 Status: Offline Thanks Meter: 163 | Quote:
Full erase..... than Full flash. use Jaf . unclick backup 308. | |
The Following User Says Thank You to reaj For This Useful Post: |
New Jumpper 2 Slove Backlighting In 1200 And 1208 And 1209 | gopalhot | Nokia Hardware & Hardware Repair | 4 | 05-14-2010 11:22 |
nokia 1202 rh112 & rh111 flash files same or not | shivashakthi | Nokia Hardware & Hardware Repair | 2 | 06-23-2009 10:16 |
nokia 7500 & 7500p flash files same or not | shivashakthi | Universalbox | 2 | 05-09-2009 17:21 |
nokia 7500 & 7500p (rm249) flash files same or | shivashakthi | Nokia Hardware & Hardware Repair | 0 | 05-09-2009 15:20 |
R200 and R210 flash files different or not? | Chuk | VLSI, Conexant, Skyworks and Old Models | 4 | 06-10-2002 07:21 |
