Old 01-07-2009, 09:42   #1 (permalink)
sigamani's Avatar
Member: 817776
Thanks Meter: 109
1208 auto restart
1208 auto restarting problem,,,,,,,,,,,,,set water lock,,,,,,,,,set working ok ,,,,,,,,,,flashed ok ,,,,,,,,,,,,,but auto restart,,,,,,,,,,,,,,,,help me ...............thanks advance,,,,,,,,,,,,,,,,,
The Following 2 Users Say Thank You to sigamani For This Useful Post:
Old 01-07-2009, 09:47   #2 (permalink)
ira balisi's Avatar
Member: 316429
Thanks Meter: 80
sir did u clean the phone 1st before you flash it?
reheat the flash ic then flash it again
The Following User Says Thank You to ira balisi For This Useful Post:
Old 01-07-2009, 09:56   #3 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
http://forum.gsmhosting.com/vbb/atta...5&d=1228589055
try this ....................
The Following 5 Users Say Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-07-2009, 09:57   #4 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
rehot uem.
not ok reball uem..
flash with higher ver and good pm file..
should work..
The Following User Says Thank You to fasany For This Useful Post:
Old 01-07-2009, 11:09   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
friend first deep clean the pcb in u/s cleaner if problem not solved then reflow or reball upp , don't touch anything else , post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 01-07-2009, 11:19   #6 (permalink)
the jinnah's Avatar
Member: 683063
Sonork: 100.1617868
Thanks Meter: 136
rehot upp only u r problem solve
i am check this problem
The Following User Says Thank You to the jinnah For This Useful Post:
Old 02-13-2009, 06:55   #7 (permalink)
Member: 724014
Thanks Meter: 16
when tourch is on its not getting restarted check that?????
The Following User Says Thank You to esskeepee7400 For This Useful Post:
Old 12-07-2010, 15:03   #8 (permalink)
Member: 710562
Originally Posted by RATHNAMOBILESS View Post
i want the auto restart solution not the dead solution. if any one can upload the auto restart solution for 1208 i will be very thankful for them.
Old 12-07-2010, 23:05   #9 (permalink)
Member: 1102669
Thanks Meter: 5
br change black real time your broblem solve
Old 04-28-2011, 18:52   #10 (permalink)
Member: 1131286
Thanks Meter: 4
1208 restart
if flash light on set is ok.then short flash light {3 point same short with 4th}
set will ok
read carefuly if ok on flash light
Old 04-28-2011, 21:35   #11 (permalink)
Member: 1475341
Thanks Meter: 6
You can check this quite easily see whether the charge on the restart, if not then the UPP
Old 05-12-2011, 14:39   #12 (permalink)
Hamidshah07's Avatar
Member: 504906
Sonork: 1604032
Thanks Meter: 141
I clean the charging base and the set is ok........
The Following User Says Thank You to Hamidshah07 For This Useful Post:
Old 02-17-2012, 20:36   #13 (permalink)
Member: 869889
Thanks Meter: 107
sir
1208 charing bus power ic &flash chang this not ok ?
whay problem
ple 100% help me
Last edited by ..::Nokian CareŽ::..; 11-17-2013 at 08:11. Reason: removed email id
1208 Auto Switch Off.. SkyNet4u Nokia Hardware & Hardware Repair 5 03-19-2010 13:04
1208 auto start with battery insert nayan Nokia Digital Core Technology 4 ( DCT-4 ) 9 11-29-2008 12:54
auto restart 1208 st.nic Nokia Hardware & Hardware Repair 5 10-20-2008 05:37
a100 restart if sim inserted auto restart BEEKUAN Panasonic 22 02-01-2005 18:16
Page generated in 0.35956 seconds with 9 queries
