Old 05-30-2009, 13:25   #1 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
1208 cnt error help pls!!!
CAN SOMEONE HELP THIS 1208 CNT ERROR!
1. I RECEIVED FROM THE CUSTOMER NK1208
THE MAIN PROBLEM IS
WHEN YOU CAN PRESS IT TONES BUTTON
SHOTDOWN.
2. I FLASH THE PHONE BUT CNT ERROR AND NOW
ITS DEAD.
SEE THIS LOG
1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.8.4]
2nd Boot: u3_2nd.fia, Ver: 4.76.0
Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
Algorithm: u3_intel.fia, Ver: 4.76.0
Algorithm Ok, MSID: 844070F5A2640EF04E778DA883
Decoded MSID: 3E4EBAE9-00D210D3-A8000000
Encoded FAID: 5FBCB39E-AF47477B-36658DB5
IMAGE: rh105_05.800
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x013AFFFF Erased, Time: 00:36
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:18
IMAGE: rh1050_nai5.80aa
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:02
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
Old 05-30-2009, 13:31   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.flash with jaf.........................
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 05-30-2009, 13:31   #3 (permalink)
salman_4_ever's Avatar
Member: 651927
Thanks Meter: 62
brother first just flash it with MCU AND PPM.if u just need to make the set power on.....after that just flash it with cnt file hope it will be fine.
if u have jaf and facing same problem then also apply same method...................
this method is tested by me
The Following User Says Thank You to salman_4_ever For This Useful Post:
Old 05-30-2009, 13:33   #4 (permalink)
Member: 547967
Thanks Meter: 653
Hello
try this
1. Erase ur Phone
2. Flash it with latest Version
3. Write PM & Unlock it.
4. Factory Settings
Thanxs
The Following User Says Thank You to mujahid_ali For This Useful Post:
Old 05-30-2009, 13:37   #5 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
1. I flash with mcu ppm only same problem
2. Flash with mcu/ppm/cnt its the same error
Old 05-30-2009, 13:37   #6 (permalink)
Member: 651927
Thanks Meter: 62
then just flash with mcu and ppm do factory set ....
if u want to power on your set.....
also post logs when u r just flashing with mcu and ppm............. ok.................
well see what kind of error u r getting
Old 05-30-2009, 13:45   #7 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
HERE IS LOG RESULT
IMAGE: rh105_05.800
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
Old 05-30-2009, 13:46   #8 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
RESULT FOR JAF
JAF version 1.98.63
Detected PKEY: VENUNO
Card life counter: 62.55%
P-key nokia module version 01.02
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Searching for default location of ini...
Checking path: \Products\RH-105\
Searching for JAF saved location of ini...
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 88720089 <=> INTEL -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
First 16 bytes: 24 12 20 02 00 9C 0B 80 2C 50 03 04 D8 08 67 00
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: 8b
Loader is ready...
MSID decoded: 3E4EBAE900D210D3A8000000
FAID: 5FBCB39EAF47477B36658DB5
Operation took 0 minutes 16 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 41 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 18 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
First 16 bytes: 24 12 20 02 00 9C 0B 80 2C 10 03 04 D8 00 64 00
Loader is ready...
MSID: 84E94DCC1158C47720BAA86FBE
MSID decoded: 3E4EBAE900D210D3A9000000
FAID: 53889DEB7AB8DA77BD0EB7F3
Operation took 0 minutes 14 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 13 seconds...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 0 minutes 15 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Operation took 0 minutes 1 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 47 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Old 05-30-2009, 13:50   #9 (permalink)
Member: 651927
Thanks Meter: 62
brother un select cnt file ....cnt file is still selected.....
just un check cnt file and then flash .......................
and post result.............................and 1 thing more if u have jaf then just try to flash with jaf
Old 05-30-2009, 13:54   #10 (permalink)
Member: 651927
Thanks Meter: 62
if the problem is still same then clean board with c.t.c and placed it under a bulb or dry it with heatgun .......... and try to flash it again
if the problem is still same then rehot flash ic.........and then flash it it will be fine................okzzzzz
Old 05-30-2009, 13:56   #11 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
W/O CNT
JAF version 1.98.63
Card life counter: 62.24%
Detected version: 01.B1, Driver version: 0, Library version: 0
Failed! Aborting!
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing...
Operation took 0 minutes 40 seconds...
Writing...
Operation took 0 minutes 19 seconds...
Restarting MCU...
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
First 16 bytes: 24 00 20 02 00 18 0B 80 2F 50 03 04 D8 00 64 00
Loader is ready...
Erasing PPM...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 25 seconds...
Failed! Aborting!
Old 05-30-2009, 13:59   #12 (permalink)
Member: 1040136
Thanks Meter: 12
Prblm shd be of pic or cpu frst reheat the pic and cpu othrwis change it
The Following User Says Thank You to nikhilmbl For This Useful Post:
Old 05-30-2009, 14:02   #13 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
Thank you all !!!
Ill be back a few hour...
Old 05-30-2009, 14:06   #14 (permalink)
Member: 1040136
Thanks Meter: 12
Reheating the pic cpu and flsh ic will ok the handset then flash it 100% sltn
Old 05-30-2009, 14:06   #15 (permalink)
Member: 651927
Thanks Meter: 62
brother do search ...............write 1208 flash ic ...........
u will get pic just rehot it then flash ur phone..................if it does not work then simply change flash ic.............
ok.............
1208 Flash Error Help M Maqsood Nokia Digital Core Technology 4 ( DCT-4 ) 3 03-31-2009 14:49
N72 Camera Error...HELP PLS. hhhhhh111111 Nokia Base Band 5 ( BB-5 ) 3 02-16-2009 08:18
Sam X640 camera error help pls mmobbilleman Samsung Hardware Repair 9 11-18-2008 16:16
Usb smart install error, Help pls "zulea" mobitek SonyEricsson (USB-Smart) 3 10-26-2005 11:45
Page generated in 0.35633 seconds with 9 queries
