Old 03-03-2010, 00:59   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::1208 failed aborting::..
1208 failed aborting,i try all versions with mxkey and jaf but still same also try to full erase and flash it again but no result
Phone Type:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\nokia\phoenix\products\rh-105\rh105_05.230
PPM Flash file: C:\Program Files\nokia\phoenix\products\rh-105\rh105_05.23ej
CNT Flash file: C:\Program Files\nokia\phoenix\products\rh-105\rh1050_nai5.23ej
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Russian,Ukrainian
MCU: C:\Program Files\nokia\phoenix\products\rh-105\rh105_05.230
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
Error in CHK...
Error Loading loader!
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader version: 04.50.00 -> Revision: 0007
Loader size is 0x5720; Loader chk: 3e
Loader is ready...
P-key nokia module version 01.02
MSID: 840B6487ADC3EB086811C5C6C7
MSID decoded: 3E4EBAE900DAC91DAA000000
FAID: 1852E3579D46B9D421A4C631
Operation took 0 minutes 12 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 37 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 20 seconds...
Restarting MCU...
PPM: C:\Program Files\nokia\phoenix\products\rh-105\rh105_05.23ej
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 849ED269B44782C2DD8912217C
MSID decoded: 3E4EBAE900DAC91DA8000000
FAID: 72D2F5540F49D48B3369AC5D
Operation took 0 minutes 7 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 11 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\nokia\phoenix\products\rh-105\rh1050_nai5.23ej
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 14 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Operation took 0 minutes 1 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 9 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Old 03-03-2010, 01:02   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i also try to cover vpp pin and flash but still failed aborting
Old 03-03-2010, 04:53   #3 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Flash with latest ver and use easy cable
Tested many time
try and post result.......
Old 03-03-2010, 05:11   #4 (permalink)
Member: 1218241
Sonork: bourouh tuandour
Thanks Meter: 20
Tested many time
II strongly agree, and the problem must be completed
Old 03-03-2010, 05:19   #5 (permalink)
Member: 744948
Sonork: jublee
Thanks Meter: 4
bro rebowl upp than flash
Old 03-03-2010, 05:48   #6 (permalink)
Member: 1244952
Thanks Meter: 10
bro.....mild reheat the UEM if still no luck reheat upp
and then flash to latest version..post the result
Old 03-03-2010, 06:02   #7 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
Bro just normaly heat ur uem with flux then check & post Result
Regard:
GSM_3GN
Old 03-03-2010, 06:20   #8 (permalink)
.:gsmXpert:.'s Avatar
Member: 471816
Sonork: 100.1623472
Thanks Meter: 57
try with 5.80 ver .................
Old 03-03-2010, 09:10   #9 (permalink)
Member: 1092450
Thanks Meter: 196
first full erase
full flash then write pm file and do unlock i think your problem will be sove
Old 03-03-2010, 09:29   #10 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Use easy cable and latest firmware. I repair many time this fault in this way.
Old 03-03-2010, 14:57   #11 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,540
This problem is possible to solve i solve this problem many time with the help of 4 pin cable
Old 03-03-2010, 15:05   #12 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,540
Try this
The Following User Says Thank You to gul551 For This Useful Post:
Old 03-03-2010, 15:07   #13 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,540
Some 1209 phones are give fail aborting try the above solution
Use plastic tap or paper to cover these two points (red mark) then flash with jaf
Old 03-03-2010, 16:29   #14 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
I COVER THESE POINT STILL SAME
Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.000
PPM Flash file: NONE
CNT Flash file: NONE
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.00ej
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai6.00ej
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.000
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 10 seconds...
Erasing...
Operation took 0 minutes 36 seconds...
Writing...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_06.00ej
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 6 seconds...
Erasing PPM...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai6.00ej
Booting phone...
MCU ID: 0x2292
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 1 minutes 49 seconds...
Failed! Aborting!
Old 03-03-2010, 17:51   #15 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Apply some heat and flash again.
..::1208 no signal after change upp::.. HUM Nokia Hardware & Hardware Repair 18 01-31-2011 14:24
..::5030c dead failed aborting::.. HUM Nokia Hardware & Hardware Repair 7 08-26-2010 05:50
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] mariaperezkkk Cyclonebox 19 03-30-2010 00:04
..::1208 flashing failed but contact service::.. HUM Nokia Hardware & Hardware Repair 22 12-04-2009 10:31
..::5130c failed aborting::.. HUM Nokia Hardware & Hardware Repair 5 09-26-2009 15:28
Page generated in 0.30494 seconds with 10 queries
