Old 01-29-2010, 12:12   #1 (permalink)
Member: 1092450
Thanks Meter: 196
1208 Failed! Aborting! plz help me
JAF version 1.98.63
Detected PKEY: 900171F3
Card life counter: 63.74%
P-key nokia module version 01.02
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Searching for default location of ini...
Checking path: \Products\RH-105\
Searching for JAF saved location of ini...
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
Languages in ppm: English,Dannish,Norwegian,Swedish
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 50
Loader is ready...
MSID: 8417CBAD2166C3F9CF610F48B5
MSID decoded: 3E4EBAE90055B404A8000000
FAID: B15E984D45D43FC09F41DEA6
Operation took 0 minutes 16 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 32 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84A991091C91308822ED3FD2B0
MSID decoded: 3E4EBAE90055B404A9000000
FAID: B2C94B22448DA3E510909245
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 11 seconds...
Writing...
Operation took 0 minutes 8 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 0 minutes 17 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 1 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 6 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Old 01-29-2010, 12:24   #2 (permalink)
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,204
SEE THIS LINK ONLY----------http://forum.gsmhosting.com/vbb/showthread.php?t=896045
JUST DO THIS.
Old 01-29-2010, 12:49   #3 (permalink)
Member: 1092450
Thanks Meter: 196
not solve problem,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 01-29-2010, 12:57   #4 (permalink)
Member: 1222076
Thanks Meter: 55
try to rehote flash ic
Old 01-29-2010, 13:01   #5 (permalink)
Member: 1141889
hi plz rehot the UEM or REBOLL THE UEM 1000000%%%%%%%%%%%% solve this problem
Old 01-29-2010, 13:09   #6 (permalink)
mlife1999's Avatar
Member: 761005
Thanks Meter: 430
brother erase the set .and flash again
The Following User Says Thank You to mlife1999 For This Useful Post:
Old 01-29-2010, 15:52   #7 (permalink)
Member: 815644
Thanks Meter: 56
easy cabel use
brother use the easy cabel your problem will be solved. i
Old 01-29-2010, 16:30   #8 (permalink)
Member: 310928
Thanks Meter: 5
try with latest firmware and first erase it and flash.
Old 01-29-2010, 17:13   #9 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
just little reheat flash ic
all will be ok...
Old 01-29-2010, 17:15   #10 (permalink)
Crazy Poster
Member: 916684
Sonork: 100.1621248
Thanks Meter: 5
pin flash cek volt......
Old 01-29-2010, 17:19   #11 (permalink)
Member: 368446
Thanks Meter: 44
flash using easy cable if not successful try reheating CPU
ur problem will be solved 100%
Old 01-29-2010, 18:06   #12 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
just erase the whole flash
flash with rh105_06.000 mcu
rh105_06.00aa ppm
rh1050_nai6.00aa cnt
or any ini as u like
try good luck
2626 after flash Failed! Aborting! plz help me... chinny1982 Nokia Digital Core Technology 4 ( DCT-4 ) 5 12-06-2009 13:07
2626 after flash Failed! Aborting! plz help me... chinny1982 Nokia Base Band 5 ( BB-5 ) 0 12-01-2009 12:00
Page generated in 0.22669 seconds with 9 queries
