11-25-2008, 07:13 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 302843 Status: Offline Thanks Meter: 111 | 1208 flase problem 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032 Algorithm: u3_st_i.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84B6E072254DAB0912EE6CF624 Decoded MSID: 3E4EBAE9-000FB51C-A9000000 Encoded FAID: 35C37565-6BCC7B73-DCE1A5A3 IMAGE: rh105_05.060 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01 Area2: 0x01010000-0x013AFFFF Erased, Time: 01:03 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:13 IMAGE: rh1050_nai5.06mg Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
The Following 2 Users Say Thank You to mahesh123 For This Useful Post: |
04-24-2009, 09:33 | #5 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Quote:
(2) Flash it (3) Write pm (4) Unlock I hope your problem will solve | |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
04-24-2009, 11:49 | #8 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india
Member: 645970 Status: Offline Thanks Meter: 157 | dear, full erase with original HWK, OR jaf ERASE MANAGER for erase, then try to flash only mcu + ppm only... if flashing sucess.... then flash cnt...... i think you will sucess..... if not sucess... clean pcb board or rehot.... then flash again... |
The Following User Says Thank You to ashish mobile For This Useful Post: |
05-10-2009, 16:04 | #11 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Badami Age: 48
Member: 307420 Status: Offline Thanks Meter: 17 | me have one problem of 1208 phone can be erased but not flashing taken i have clean the pcb and full erase with mt and now heat the flash ic and cpu now same problem what can i do this is log of ufs i tested man .. before weeks and works with all dct4 will .. just if you lose imei net UEM problem .. 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.8.2] 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u3_amd.fia, Ver: 4.76.0 Algorithm Ok, MSID: 8422E41940498B8951514E8423 Decoded MSID: 3E4EBAE9-009F900B-A8000000 Encoded FAID: E17C172B-4E43433E-AA1C6536 IMAGE: rh105_05.800 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:27 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01008000:08 Process Failed, Repowering Mobile |
The Following User Says Thank You to jameel_badami For This Useful Post: |
05-10-2009, 16:05 | #12 (permalink) |
Member: 307420 Status: Offline Thanks Meter: 17 | me have one problem of 1208 phone can be erased but not flashing taken i have clean the pcb and full erase with mt and now heat the flash ic and cpu now same problem what can i do this is log of ufs 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.0.8.2] 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u3_amd.fia, Ver: 4.76.0 Algorithm Ok, MSID: 8422E41940498B8951514E8423 Decoded MSID: 3E4EBAE9-009F900B-A8000000 Encoded FAID: E17C172B-4E43433E-AA1C6536 IMAGE: rh105_05.800 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:27 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:02 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01008000:08 Process Failed, Repowering Mobile |
05-10-2009, 16:09 | #13 (permalink) | |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Quote:
try to flash wit j.a.f | |
The Following User Says Thank You to Repair4u For This Useful Post: |
11-04-2010, 08:06 | #15 (permalink) | |
Registered User Join Date: Sep 2010 Location: Sambalpur
Member: 1392270 Status: Offline Sonork: sanjukta Thanks Meter: 1 | Quote:
when u flash set your flash speed to xslow 100% done i have done this errer | |
The Following User Says Thank You to tapan@sanju For This Useful Post: |
N72 flasing problem, help plsssss | abbeylee | Nokia Base Band 5 ( BB-5 ) | 3 | 03-01-2007 13:56 |
k510i flasing problem | ngaia | Sony Ericsson Hardware Repair | 0 | 02-16-2007 07:26 |
Z520i flasing problem | Alex8392003 | Cruiser Suite | 0 | 02-08-2006 08:50 |
3200 flasing problem | Alinush75 | Griffin | 2 | 09-28-2004 09:41 |
