Old 05-11-2008, 11:58   #1 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
is 1208 flashing possiable via ufs
hi friends I have a 1208 with software problem , I don't have jaf right now so is possiable to flash 1208 in ufs?
please guide me friends & what is the procedure? means can I select 1600 (rh-64) to flash 1208
waiting for reply
Old 05-11-2008, 17:27   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Yes possible but not CLONE UFS.
It is possible only ORIGINAL UFS HWK.
Post result.
Old 05-11-2008, 17:32   #3 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
do you know there is cracked JAF software now,. use it if u like on your ufs box 100%....
Old 05-11-2008, 17:44   #4 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Dont use cracked software it will damaged your phone use UFS HWK for flashing.
Old 05-11-2008, 18:42   #5 (permalink)
Registered User
Member: 598390
Thanks Meter: 32
How can be done UFS +HWK ?Plz guide me brothers.
how can i flash 1200 or 1208 with ufs
is that i should select 1110i(rh-93)for 1200?
PLZ guide me
Old 05-11-2008, 19:52   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
waiting for reply
" it is a trick & logical point too, any set which takes ui settings completly by ufs is subjected to flash, thanx"
Old 05-11-2008, 20:50   #7 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
thanks for quick reply friends , I will try & post result soon
Old 05-12-2008, 09:02   #8 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 253
You can flash 1208 by using ufs with out hwk just connect ufs select dct-4 and dte-1 (d211) first of all flasn mcu file then ppm and then cnt file one by one then make ui setting your mobile will be work 10000000% it is tested by me many time. [email protected]
Old 05-13-2008, 11:52   #9 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
is it really tested? I am affriad to do this
waiting for reply
Old 05-13-2008, 13:10   #10 (permalink)
watari31's Avatar
Member: 141262
Thanks Meter: 348
waiting for reply
it is tested at the same time it was risky!!! so is up to you if you wanna try it!!!
Old 05-13-2008, 13:44   #11 (permalink)
Member: 696372
Thanks Meter: 11
pls dont try this at home or school(wwe dialog),this is a wrong method in this way imei number may be currepted so dont try
Old 05-13-2008, 15:25   #12 (permalink)
Member: 706300
Thanks Meter: 147
re:
waiting for reply
" bro do one thing if u posess 1200 or 1208 ok set, then try on ufs with ui settings if ui settings done u would get ur point & vice-versa, if u will get positive result which means local mode is ok only then u can select 1600 model etc & put 1208 files (mcu&ppm) instead of 1600 files & flash"
Old 05-22-2008, 12:30   #13 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
who said crack software damages phones,wel hehehehe, i just flashed 1200 with cracked jaf all all worked good for me.,
goodluck to all memeber
Old 05-22-2008, 19:10   #14 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
done ui setting & the previous one ok now but another one (1208) is blinkilg so I want to flash the set
I get positive result means local mode is ok on blinking one , tomorrow I will flash the set & post the result my friend
Old 05-22-2008, 19:15   #15 (permalink)
Member: 706300
Thanks Meter: 147
re:
" bro u will definetly get the positive result, thanx"
-= k800i redblink,done by setool2 via UFS & via voltage regulator =- bronce SETool2 9 08-18-2011 14:06
1208 flashing error is it hardware dapinderjit Nokia Hardware & Hardware Repair 12 08-01-2009 18:35
DCT4 Imei Change via UFS karwos UFS2 + UFS3-Tornadoflasher 7 07-06-2005 17:51
Page generated in 0.23145 seconds with 10 queries
