09-27-2009, 08:17 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | 1208 hang after 10 second and switch off I remoov audio ic but still same fault.I do flash with latest version,write good pm and unlocked but still.I check it self test hwk there is RF CHIP ID TEST FAILD.what is this problem .Have any expert tested solution plz share here. |
09-27-2009, 08:24 | #4 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | Quote:
09-27-2009, 08:37 | #6 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | I think no need rpl cause imei is ok and set is unlocked.info good also. check here MCU SW : V 5.91 27-03-09 RH-105 (c) NMP PPM SW : V 5.91 27-03-09 RH-105 (c) NMP EL Prd.Code: 0546789 Bpr.Code: 0544418 Prod.Sn : DBM506781 HW Vers : 1502 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: SDI:NAXv89 S6B33BD IMEI : 356047-03-092403-0 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00003560470309240300 SL Aux : 000B0000 HW Sig : AFC5AD31032F4216 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Test Equipment |
09-27-2009, 08:50 | #9 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
change new uem ic................ | |
09-27-2009, 09:00 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | bro umesh write rpl i,ts rpl problam not for hardware or software i,ts problam rpl write rpl and problam solve if u dont have rpl pm me i can give u 1 rpl |
3220 switch off after 10 seconds | pankajkukar2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-01-2010 07:36 |
6600 auto switch off after 10 second | funsuk vangdu | Nokia Hardware & Hardware Repair | 1 | 02-19-2010 18:39 |
1202 water damage hang after 10 seconds | Maiwand khan | Nokia Hardware & Hardware Repair | 3 | 06-04-2009 07:34 |
2112 switch off after 10 seconds | sgs_41 | Nokia CDMA | 2 | 05-02-2007 18:50 |
