Old 06-25-2008, 15:29   #1 (permalink)
Member: 798021
Thanks Meter: 5
1208 keypad
Nokia 1208 key pad is not working plese help me.
The Following 4 Users Say Thank You to preetgiftshopee For This Useful Post:
Old 06-25-2008, 15:36   #2 (permalink)
Member: 483720
Thanks Meter: 116
try z2400 keypad ic
The Following 2 Users Say Thank You to ptnetwork For This Useful Post:
Old 07-07-2008, 16:35   #3 (permalink)
Member: 776072
key pad problem
chenge the key pad ic ... its in down on disply cannector
The Following User Says Thank You to narayan_athani For This Useful Post:
Old 07-14-2008, 16:40   #4 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
Thanks Meter: 316
already tell u the best process.......
keep trying then tell me the result.....
The Following User Says Thank You to shohag For This Useful Post:
Old 07-14-2008, 17:07   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,693
change keypad ic brtr u problem will solve ......
The Following User Says Thank You to digitized For This Useful Post:
Old 08-07-2008, 09:46   #6 (permalink)
Member: 748921
Sonork: im_sam121
Thanks Meter: 3
Hi, i have one problem nokia 1200/1208 menu & 9 button not work i change the ic but problem is still any one help me
The Following User Says Thank You to im_sam121 For This Useful Post:
Old 08-20-2008, 10:04   #7 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
The Following User Says Thank You to MMDEBILI For This Useful Post:
Old 09-09-2008, 12:22   #8 (permalink)
Member: 405422
Thanks Meter: 3
1200 * ka butten nahi chal raha i changed 4keypad icbut the condition same.i clean the board. clean the tag of
but codition same.pleeeeeeeeeee help
The Following User Says Thank You to subhan_ali For This Useful Post:
Old 09-18-2008, 17:42   #9 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 436
Arrow
my problem same already change key ic rehot cpu but menu button&cleare button not working
The Following User Says Thank You to RATHNAMOBILESS For This Useful Post:
Old 09-19-2008, 08:07   #10 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
reflow cpu if not done reball that
sp
The Following User Says Thank You to sphameed For This Useful Post:
Old 09-19-2008, 08:11   #11 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
bro check keypad ic one more time
1,reball cpu 2,change cpu
best of luck
SP
WISDOM IS BETTER THAN GOLD&DIAMOND
Old 09-19-2008, 09:59   #12 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,509
chang the key pad ic
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 09-19-2008, 10:04   #13 (permalink)
Member: 275451
Thanks Meter: 84
change keypad ic..chk continuity...to keypad...
The Following User Says Thank You to as_ji For This Useful Post:
Old 09-19-2008, 10:10   #14 (permalink)
billal1050's Avatar
Member: 860925
Sonork: Now I'M Malaysia
Thanks Meter: 294
Originally Posted by MMDEBILI View Post
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
ok ok ok ok ok
Whats This Means........Post Clearly.................
The Following 2 Users Say Thank You to billal1050 For This Useful Post:
Old 09-23-2008, 21:20   #15 (permalink)
Member: 322024
Thanks Meter: 5
hi to all in nokia 1208 (0_button) is not work when replace new key pad ic plzzzzzzzzzzzzzz help
The Following 2 Users Say Thank You to aamer009 For This Useful Post:
Nokia 1208 keypad problem ? Rizwan ch08 Nokia Hardware & Hardware Repair 11 11-07-2013 11:48
1208 keypad prob. mahesh123 Nokia Hardware & Hardware Repair 7 02-05-2011 10:58
1208 keypad not working crackp0d Nokia Digital Core Technology 4 ( DCT-4 ) 5 08-03-2010 10:27
Nokia 1208 keypad sameer918 Nokia Hardware & Hardware Repair 3 11-26-2008 00:41
1208 keypad SMDSAFE Nokia Hardware & Hardware Repair 2 08-14-2008 10:59
Page generated in 0.42209 seconds with 8 queries
