11-02-2009, 23:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | 6280 sim registration failed...sometimes... have this 6280. it is not barred at all. In fact it calls but every now and then sim registration failed shows up. I repeat its not a lost or stolen phone. Its a hardware problem 100% in this case. thanks for any help |
11-03-2009, 00:55 | #4 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
Hi If it comes randomly it means something has bad ground joints so unsoldered. I'd say it's a RF processor problem, but you can still check RETU, Flash, sram and RAP3G ics. I experienced a similar problem on a 7250 in the past I replaced HAGAR and reballed UEM. Try toturn on the phone with no back cover and apply some pressure with fingers on each ic when it happens , don't forget to attach a sim card BR Max_B | |
11-03-2009, 05:25 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
if not work change battry conector....... | |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
11-03-2009, 06:39 | #9 (permalink) | ||
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
1)sim connection a)sim ic problem and sim tray 2)battery problem a)bsi line make this problem 3)stolen phone i got this same complanit 6300,im try to upload pm via sx4 problem 100%solved u must try to upload pm via sx4 then check more problem faced post result | ||
11-03-2009, 06:46 | #10 (permalink) | |
11-03-2009, 09:24 | #13 (permalink) |
Freak Poster Join Date: Jun 2007 Location: China Age: 41
Member: 521025 Status: Offline Sonork: 100.1605431 Thanks Meter: 154 | hello brother not posibale and just write bakup and write rpll 123456123456... and then factry set and format just 25 and 15 min use [email protected] |
11-20-2009, 04:19 | #15 (permalink) | |
Freak Poster Join Date: May 2006
Member: 274214 Status: Offline Thanks Meter: 4 | Quote:
I have this phone got problem with not charging, sim card registration failed sometime, also sometime phone start hang after Nokia sign. I pulled the battery connectors up and stick out a bit, all the problem solved. I think the actual problem is that the BSI line lost connection. | |
6280 sim registration failed but sim ic ok | luyanda | Nokia Hardware & Hardware Repair | 10 | 01-09-2010 07:01 |
3510ì Sim Registration Failed! Help! | Maurone | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 01-07-2005 14:23 |
sim registration failed | jonzey | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-08-2003 23:20 |
3310 says sim registration failed | junoon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 12-16-2002 10:47 |
8310 Sim registration failed after wrong unlock | tyro628 | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 11-09-2002 19:03 |
