Old 08-06-2008, 16:09   #1 (permalink)
Member: 174094
Thanks Meter: 74
1208 local mode
1208 local mode
i remove 2 components as mentioned in forum .....same prob
i remove base charger same
flash with jaf same but in normal mode displays*inser sim
one ching not done components links to bsi i dont know no shematics on hand
with digital multimeter no resistance between gnd & bsi it means circuit
broken need be repaired & no other phone on hand
i need help
thanks
Old 08-06-2008, 16:25   #2 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
Originally Posted by habibkhalil View Post
1208 local mode
i need help
thanks
u remove a resister still same problem, any dead board remove a resister past there i try 3 mobile is working
Old 08-06-2008, 16:29   #3 (permalink)
Member: 174094
Thanks Meter: 74
can you mention it's value in kiloohms i'll check in any other board
thanks
Old 08-06-2008, 16:45   #4 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
thanks
Old 08-06-2008, 19:16   #5 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
thank u bro usefull post
Old 05-28-2009, 16:32   #6 (permalink)
Member: 890328
Thanks Meter: 50
Post please help
in nokia 1208 displaying not charging the same component i have removed & removed zenor diode also but its showing the same what z the solution please help me
Old 05-28-2009, 17:12   #7 (permalink)
nost's Avatar
Member: 197360
Thanks Meter: 25
post procedura which you used with jaf
only way for me is:
selec:
factory set, manual flash, warranty and unlock on flash settings frame
chose any firm for flash tree parts: mcu, ppm and cnt
for example
mcu: rh106_4.110
ppm: rh106_4.110ub
cnt: rh106_nai4.11ub_ita
post results
1200 and 1208 local mode DIGITAL BABU Nokia Hardware & Hardware Repair 46 09-30-2011 09:05
nokia 1200/1208 local mode solution himanshu taldar Nokia Hardware & Hardware Repair 21 06-10-2009 06:34
Nokia 1200 1208 Local Mode or Test mode Problem solution Diagram tehseen ahmed Nokia Hardware & Hardware Repair 2 04-01-2009 07:35
Nokia 1208 Local mode (URGENT) Mobile_plus Nokia Hardware & Hardware Repair 16 05-29-2008 12:03
Page generated in 0.22139 seconds with 11 queries
