Old 02-20-2009, 04:32   #1 (permalink)
nazrul islam's Avatar
Member: 756569
Thanks Meter: 185
1208 problem
set come with restarte problem, i was flash with latest flash file, same, then flash with 4_00 . but same, i was open the phone see some carbon (dast) in display connector i was clene it , now set open with display after 20-40 sec set display only blue light. i am flash agine, change rabon change display, if i connect display without rabon also same .please please please help me......
Old 02-20-2009, 06:41   #2 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
bro problem in display connector becz as u said it was restarting problem before u cleaning the connector so to get the first position u need to work on display connector & check the connections using schematics, thanx
Old 02-20-2009, 06:56   #3 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
try this i think solve ur problem
The Following 2 Users Say Thank You to jabed_net For This Useful Post:
Old 02-20-2009, 12:27   #4 (permalink)
Member: 756569
Thanks Meter: 185
thinks, But my problem not solve. frist i remove this two resistor, not work ,then i change this two but same. any other idea ??????
Old 02-20-2009, 12:35   #5 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 284
what Exactlly YOUR PROBLEM
1200 phone restarts when you go to tones
is it This
Old 02-20-2009, 12:35   #6 (permalink)
Registered User
Member: 474301
Thanks Meter: 2
Old 06-08-2009, 09:45   #7 (permalink)
Member: 1046052
Thanks Meter: 6
hello bro
please solve my problem 1208 prees power on boton Nokia icon then blue display
Old 06-08-2009, 09:51   #8 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
brother i think your phone is water damage so rehot processor your problem will b solved thanks
Old 06-08-2009, 11:42   #9 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
try reball cpu ic sir
nokia 1208 probleme son FLASHDIMO Nokia Hardware & Hardware Repair 2 06-06-2011 03:33
1208 problem...???? mangofree Universalbox 14 03-28-2009 08:39
1208 problem syed tuqeer HWK 3 08-22-2008 09:58
1208 problems nunu_gabriel Multi-Box 10 06-25-2008 09:15
unlock 1208 problem Tomy6565 MT-BOX 1 06-06-2008 02:04
Page generated in 0.24637 seconds with 9 queries
