11-05-2009, 07:47 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: ODISHA Age: 38
Member: 843479 Status: Offline Thanks Meter: 48 | 1208 restart after few minutes I have flashed it with hwk 5.80 version changed the charging connector also.but the problem is same now. Please give me any solution................. |
The Following User Says Thank You to vikashmeher For This Useful Post: |
11-05-2009, 08:10 | #6 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | first full flash the phone if same just reball upp ,tested by me with 4sets , post result |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
11-05-2009, 08:14 | #7 (permalink) | |
Member: 843479 Status: Offline Thanks Meter: 48 | Quote:
================= MCU SW : V 5.80 14-11-08 RH-105 (c) NMP PPM SW : V 5.80 14-11-08 RH-105 (c) NMP MG Prd.Code: 0549920 Bpr.Code: 0515534 Prod.Sn : IEK590858 HW Vers : 2602 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: TPO:NAXv8B LDS184 IMEI : 352931-02-790198-2 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00003529310279019800 SL Aux : 000B0000 HW Sig : 768580B5212B40A3 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment | |
The Following 2 Users Say Thank You to vikashmeher For This Useful Post: |
11-05-2009, 08:25 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | never show your imei on open forum your imei is ok open JAF in dct4 section go to imei tool chacked uem change chacked manual mode and click read uem after reading uem then post logs |
The Following User Says Thank You to israrbjr For This Useful Post: |
11-05-2009, 10:29 | #12 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, tested solution is flash with 3.72 version and all will be ok i test it several time post your result Jimmy |
3110c restarts after few minutes please see the logs | subra007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-27-2011 07:38 |
Sharp 705sh restart after few minutes.. | dsaxor | TORNADO - SIM | 6 | 04-05-2008 03:37 |
nec e228 restarts every few minutes | syms | NEC | 5 | 02-25-2008 21:36 |
Samsung T100's display shut down after few minutes | roller | Samsung Hardware Repair | 2 | 12-06-2002 22:53 |
