-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   1208 show beep but no charge the battry (http://forum.gsmhosting.com/vbb/f148/1208-show-beep-but-no-charge-battry-743058/)
ADNAN440-BANNU 04-30-2009 12:53
i insert the charger and show only beep but no charge the mobil
i changer the jack
i change the coil fuse r22 but same
biniesh_08 04-30-2009 14:36
br power ic changed your pro solve................
erick_ponsel88 04-30-2009 15:02
change small crystal ic..
Br..
shahidsattar 04-30-2009 16:31
i changer the jack
remove the four leg resister near uem
mahbubalfa 04-30-2009 19:54
Bro..change charging resister ..(R22)..99% ok.
ashish mobile 04-30-2009 20:01
DEAR, change 4 legs resistance nearby U.E.M ,,,, BRO...
ADNAN440-BANNU 05-01-2009 06:21
i remove the 4 legs resistor but sameeeeeeeeeeee
baldev 05-01-2009 06:42
i changer the jack
remove capacitor and resistor behind battery connector and resistor just behind data cable jack pins.
vaghubha_sodha 05-01-2009 06:52
1200 chargin not carrging local mode solu
ADNAN440-BANNU 05-02-2009 07:42
i remove 4 legs resistor
i remove resistor and capicator near battry connector
i change the 4 legs resistor but same
s.s.s.s. 05-02-2009 07:52
bro,
flash with good pm.......
kulwinder2002 05-02-2009 08:42
its shwing charging or just give bbep when we connect
ADNAN440-BANNU 05-02-2009 12:14
it show only beep no show the charge bars
shehryar mardan 08-16-2010 16:48
2. change r22
http://i48.tinypic.com/21cxxjn.jpg
[email protected]
abdurrahimsagar 08-16-2010 17:17
i changer the jack
are you fist try too Local mode, Test mode solution http://forum.gsmhosting.com/vbb/f148...5/#post6195671
http://img836.imageshack.us/img836/1501/1200.jpg
then try it your problem 100% solve
http://forum.gsmhosting.com/vbb/6135013-post2.html
http://img713.imageshack.us/img713/1700/1200111.jpg
Page generated in 0.27225 seconds with 5 queries
