Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 04-30-2009, 11:53   #1 (permalink)
Member: 753348
Sonork: no
1208 show beep but no charge the battry
i insert the charger and show only beep but no charge the mobil
i changer the jack
i change the coil fuse r22 but same
The Following User Says Thank You to ADNAN440-BANNU For This Useful Post:
Old 04-30-2009, 13:36   #2 (permalink)
biniesh_08's Avatar
Member: 843418
br power ic changed your pro solve................
The Following User Says Thank You to biniesh_08 For This Useful Post:
Old 04-30-2009, 14:02   #3 (permalink)
erick_ponsel88's Avatar
Member: 969971
Sonork: Vincent_Lim
change small crystal ic..
Br..
The Following User Says Thank You to erick_ponsel88 For This Useful Post:
Old 04-30-2009, 15:31   #4 (permalink)
shahidsattar's Avatar
Member: 388454
i changer the jack
remove the four leg resister near uem
The Following User Says Thank You to shahidsattar For This Useful Post:
Old 04-30-2009, 18:54   #5 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274
Bro..change charging resister ..(R22)..99% ok.
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 04-30-2009, 19:01   #6 (permalink)
Member: 645970
DEAR, change 4 legs resistance nearby U.E.M ,,,, BRO...
The Following User Says Thank You to ashish mobile For This Useful Post:
Old 05-01-2009, 05:21   #7 (permalink)
Member: 753348
Sonork: no
i remove the 4 legs resistor but sameeeeeeeeeeee
Old 05-01-2009, 05:42   #8 (permalink)
baldev's Avatar
Member: 153805
i changer the jack
remove capacitor and resistor behind battery connector and resistor just behind data cable jack pins.
The Following User Says Thank You to baldev For This Useful Post:
Old 05-01-2009, 05:52   #9 (permalink)
vaghubha_sodha's Avatar
Member: 823633
Sonork: 9898260467
1200 chargin not carrging local mode solu
The Following User Says Thank You to vaghubha_sodha For This Useful Post:
Old 05-02-2009, 06:42   #10 (permalink)
Member: 753348
Sonork: no
i remove 4 legs resistor
i remove resistor and capicator near battry connector
i change the 4 legs resistor but same
Old 05-02-2009, 06:52   #11 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
bro,
flash with good pm.......
The Following User Says Thank You to s.s.s.s. For This Useful Post:
Old 05-02-2009, 07:42   #12 (permalink)
Member: 629694
its shwing charging or just give bbep when we connect
The Following User Says Thank You to kulwinder2002 For This Useful Post:
Old 05-02-2009, 11:14   #13 (permalink)
Member: 753348
Sonork: no
it show only beep no show the charge bars
Old 08-16-2010, 15:48   #14 (permalink)
shehryar mardan's Avatar
Member: 1033862
Sonork: 0341-5101001
2. change r22
shehryar2009@yahoo.com
Old 08-16-2010, 16:17   #15 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
i changer the jack
are you fist try too Local mode, Test mode solution 1200,1208,1209 test mode, Local Mode, Normal mode ok but power not on 100% teste
then try it your problem 100% solve
1208 Show Charging Bar
The Following 3 Users Say Thank You to abdurrahimsagar For This Useful Post:
1208 on with supply but no on with battry AS_ADNAN440 Nokia Hardware & Hardware-Repair Area 5 07-05-2009 11:54
1208 on withe suuply but no on with battry ADNAN440-BANNU Nokia Hardware & Hardware-Repair Area 8 04-14-2009 18:24
6300 chrging show but no charge battry chorahi Nokia Hardware & Hardware-Repair Area 15 03-02-2009 08:01
5300 showing chareging but no charge gsm4sp Nokia Hardware & Hardware-Repair Area 7 08-28-2008 07:42
1200 beep but no charging classic mobiles Nokia Hardware & Hardware-Repair Area 3 05-29-2008 11:39
Page generated in 0.46897 seconds with 11 queries
