Old 07-27-2010, 15:08   #1 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 140
1208 Show Charging Bar
When insert battery it show charging bar which not moving but when press power button than it on and work fine but not charging. I try to replace R2900 but still same than remove R2900 it solved (charging still not work) did remove R2900 is safe mean removing R2900 make which kind of fault in future? Charging is not matter it can be use Universal Charger. Please reply urgent. Waiting for your kind response.
Kind regards,
Vicky
Old 07-27-2010, 15:13   #2 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
Arrow
Kind regards,
Vicky
re hot and change it 100% solve your problem im tested
The Following 9 Users Say Thank You to abdurrahimsagar For This Useful Post:
Old 07-27-2010, 19:04   #3 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
if ur phone is in good condition and not water damaged etc then just write good pm file with jaf other wise try rahim's solution
The Following User Says Thank You to bruightmobile For This Useful Post:
Old 07-28-2010, 04:31   #4 (permalink)
wsw243's Avatar
Member: 248050
Sonork: 100.1624328
Thanks Meter: 140
I have try both solution replace R2001/PM write but still same. Please post another solution. Waiting for your kind response.
Kind regards,
Vicky
Old 07-28-2010, 07:01   #5 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
no any solution just chng or reball uem.......
Old 07-28-2010, 07:02   #6 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Hello,
Just check it with other battary sometimes faulty battary also cause same fault !
Old 07-28-2010, 07:05   #7 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
its a uem problem,give small heat on it or reball.
Old 07-28-2010, 07:06   #8 (permalink)
Member: 488536
Thanks Meter: 36
full erase and flash, write new pm after unlock thats all,,,,,,,,,,,,,,,,
Old 07-28-2010, 07:40   #9 (permalink)
Registered User
Member: 1087294
Thanks Meter: 252
yes finally its uem fault so change uem but its little risky
Old 07-28-2010, 08:38   #10 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
change jack dear
change ic
change 47k resistance
Old 08-02-2010, 12:25   #11 (permalink)
Member: 769994
Thanks Meter: 23
how about this one try it
[IMG]http://i392.photobucket.com/albums/pp10/highvoltage_sarmient
/1200notcharging.jpg[/IMG]
hope it can help you
Old 08-02-2010, 15:19   #12 (permalink)
Member: 775587
Thanks Meter: 29
only changing uem can fix this.
Old 03-09-2014, 09:20   #13 (permalink)
Member: 2091907
Thanks Meter: 6
its 100% uem problem
Old 03-09-2014, 17:04   #14 (permalink)
Member: 2142840
Thanks Meter: 5
quartz is problem, change it
Old 03-09-2014, 17:29   #15 (permalink)
Member: 1448406
Thanks Meter: 5
this is from cpu i was solve 3 set by rehoting
Charging. PhoeniX Nokia Hardware & Hardware Repair 7 07-06-2004 08:35
51xx charging problem kage Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 03-06-2002 00:42
My 5130 shows 25 mA in stdby, another 4mA in Netmonitor test 23 mr_x4you Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-23-2001 11:07
6210 dont show the security code Moc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 12 10-09-2001 14:00
warning!!!! cold barring after unlock 8850 v5.25 with nokey by zulea DREAMGSM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-27-2001 02:51
Page generated in 0.25536 seconds with 9 queries
