1208b Convert But No Signal Flash with 1208 RM-105 Write Good Pmm Change 2 Filters Unlock and Factory Setting. But no network. Before this i have convert many phones and also 1208b but this time very strange. I am in Pakistan. |
MCU SW : V 3.72 14-09-07 RH-105 (c) NMP PPM SW : V 3.72 14-09-07 RH-105 (c) NMP IC Prd.Code: 0550577 Bpr.Code: 0515534 Prod.Sn : DON420196 HW Vers : 1603 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: P06w45.v37 LCD Type: SDI:NAXv89 S6B33BD IMEI : 011539-00-446961-9 SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00000115390044696100 SL Aux : 000B0000 HW Sig : B644274B345C08E6 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment |
have u write pm? if u change filter may b ur filters r damage in such case change both of them otherwise just make jumper |
i also use this but same |
Here is its origional information. Phone Type: RH-106 SW Version: V 5.23 03-10-08 RH-106 (c) NMP Imei plain: 01153900446961-9 Product Code: 0563363 Language Pack: - not available. "C:\Program Files\Nokia\Phoenix\Products\RH-106" folder created. Imei net: 01153900446961 Version: SIMLOCK SERVER Provider: T-Mobile USA , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 9000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 310160 - [United States-T-Mobile USA ] BLOCK 2: 1.LOCKED (MCC+MNC): 310200 - [United States-T-Mobile USA ] BLOCK 3: 1.LOCKED (MCC+MNC): 310210 - [United States-T-Mobile USA ] BLOCK 4: 1.LOCKED (MCC+MNC): 310220 - [United States-T-Mobile USA ] BLOCK 5: 1.LOCKED (MCC+MNC): 310230 - [United States-T-Mobile USA ] BLOCK 6: 1.LOCKED (MCC+MNC): 310240 - [United States-T-Mobile USA ] BLOCK 7: 1.LOCKED (MCC+MNC): 310250 - [United States-T-Mobile USA ] BLOCK 8: 1.LOCKED (MCC+MNC): 310260 - [United States-T-Mobile USA ] BLOCK 9: 1.LOCKED (MCC+MNC): 310270 - [United States-T-Mobile USA ] BLOCK 10: 1.LOCKED (MCC+MNC): 310310 - [United States-T-Mobile USA ] BLOCK 11: 1.LOCKED (MCC+MNC): 310580 - [United States-Inland Cellular Telephone Company ] BLOCK 12: 1.LOCKED (MCC+MNC): 310660 - [United States-T-Mobile USA ] BLOCK 13: 1.LOCKED (MCC+MNC): 310800 - [United States-T-Mobile USA ] BLOCK 14: 1.LOCKED (MCC+MNC): 310490 - [United States-T-Mobile USA ] Imei net: 01153900446961 Version: SIMLOCK SERVER Provider: T-Mobile USA , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 9000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 310160 - [United States-T-Mobile USA ] BLOCK 2: 1.LOCKED (MCC+MNC): 310200 - [United States-T-Mobile USA ] BLOCK 3: 1.LOCKED (MCC+MNC): 310210 - [United States-T-Mobile USA ] BLOCK 4: 1.LOCKED (MCC+MNC): 310220 - [United States-T-Mobile USA ] BLOCK 5: 1.LOCKED (MCC+MNC): 310230 - [United States-T-Mobile USA ] BLOCK 6: 1.LOCKED (MCC+MNC): 310240 - [United States-T-Mobile USA ] BLOCK 7: 1.LOCKED (MCC+MNC): 310250 - [United States-T-Mobile USA ] BLOCK 8: 1.LOCKED (MCC+MNC): 310260 - [United States-T-Mobile USA ] BLOCK 9: 1.LOCKED (MCC+MNC): 310270 - [United States-T-Mobile USA ] BLOCK 10: 1.LOCKED (MCC+MNC): 310310 - [United States-T-Mobile USA ] BLOCK 11: 1.LOCKED (MCC+MNC): 310580 - [United States-Inland Cellular Telephone Company ] BLOCK 12: 1.LOCKED (MCC+MNC): 310660 - [United States-T-Mobile USA ] BLOCK 13: 1.LOCKED (MCC+MNC): 310800 - [United States-T-Mobile USA ] BLOCK 14: 1.LOCKED (MCC+MNC): 310490 - [United States-T-Mobile USA ] Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.6 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-106_01153900446961_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01153900446961 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN i also use this http://i43.tinypic.com/2aiq8n8.jpg |
I unlock it using this Imei net: 01153900446961 Version: SIMLOCK SERVER Provider: T-Mobile USA , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 9000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 310160 - [United States-T-Mobile USA ] BLOCK 2: 1.LOCKED (MCC+MNC): 310200 - [United States-T-Mobile USA ] BLOCK 3: 1.LOCKED (MCC+MNC): 310210 - [United States-T-Mobile USA ] BLOCK 4: 1.LOCKED (MCC+MNC): 310220 - [United States-T-Mobile USA ] BLOCK 5: 1.LOCKED (MCC+MNC): 310230 - [United States-T-Mobile USA ] BLOCK 6: 1.LOCKED (MCC+MNC): 310240 - [United States-T-Mobile USA ] BLOCK 7: 1.LOCKED (MCC+MNC): 310250 - [United States-T-Mobile USA ] BLOCK 8: 1.LOCKED (MCC+MNC): 310260 - [United States-T-Mobile USA ] BLOCK 9: 1.LOCKED (MCC+MNC): 310270 - [United States-T-Mobile USA ] BLOCK 10: 1.LOCKED (MCC+MNC): 310310 - [United States-T-Mobile USA ] BLOCK 11: 1.LOCKED (MCC+MNC): 310580 - [United States-Inland Cellular Telephone Company ] BLOCK 12: 1.LOCKED (MCC+MNC): 310660 - [United States-T-Mobile USA ] BLOCK 13: 1.LOCKED (MCC+MNC): 310800 - [United States-T-Mobile USA ] BLOCK 14: 1.LOCKED (MCC+MNC): 310490 - [United States-T-Mobile USA ] Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.6 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-106_01153900446961_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01153900446961 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
brother use rh-106 file hope ur problem will b solved |
I think rh-106 dose not have 900 and 1800 band |
brother try to flash in rh-105.... before you flash to rh-105 try to run self test...then you can see what is the problem... but if its all pass in running self test..then its the time you flash in rh-105.... |
Sir once I solved this problem in 6030b with the method I post above. I m not saying that this is a perfect solution this is one option,check and post result,hope it will b usefull for u? |
bro 6030 and 1208 is not same |
can anyone help me . i am still waiting |
1 Attachment(s) her is test reprot is there any hardware fault |
