Old 09-29-2010, 08:34   #1 (permalink)
Member: 301177
Thanks Meter: 91
1209 contact service
Bro
i have nokia 1209 it shows contact service when i put the ufs cable and check with normal mode the set will ok but when i put the battery in the phone and check it show "contact service" i also remove 2 capistor of battery connector but nor ok
guide me how can i solve this problem
Old 09-29-2010, 08:42   #2 (permalink)
chipset experts's Avatar
Member: 1312914
Thanks Meter: 111
Originally Posted by ameho0102 View Post
Bro
first erase ur phone and then flash it again with latest ver...
then write good pm and unlock it....
if still same then change uem....
Old 09-29-2010, 08:46   #3 (permalink)
Member: 888936
Thanks Meter: 9
if you have ufs-hawk it is simple.just do all UI settings and after that all good
Old 09-29-2010, 09:07   #4 (permalink)
Member: 540345
Thanks Meter: 175
flash with up ver....
write good pm...
unlock & check then....
Old 09-30-2010, 12:33   #5 (permalink)
Member: 1263622
Thanks Meter: 149
ple,help my nokia 1200 contact service show.flash ok,ufs,, normal mode ok but no solve this poblem
Old 09-30-2010, 12:54   #6 (permalink)
Member: 500885
Thanks Meter: 77
clean the pcb check the latest ver remove or change the charging connector,display conn try to this
Old 09-30-2010, 13:01   #7 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
!st flash with latest version..........
If still same, check selftest, if its showing flash checksum test failed. Just resold flash ic.
I've tried it on many sets. It works.
Old 09-30-2010, 14:00   #8 (permalink)
Member: 1276424
sim lock update just mx key your problem is solved
Old 09-30-2010, 14:13   #9 (permalink)
tanveeranjum's Avatar
Member: 386511
Thanks Meter: 305
just unlock or send me info.....................................
Old 09-30-2010, 17:16   #10 (permalink)
Member: 476469
Thanks Meter: 10
shortly result of all it may hard ware or softwar problem first flash with anyversion thats u have.ten simply unlock if theset normaly on but no signalten only rite1208 1200 1209 any pm then factri set it ok
2---ifpoblem remain sam then only change ch jak or lcd or heat uem .set ok 100% chalenge
Old 09-30-2010, 17:19   #11 (permalink)
Member: 476469
Thanks Meter: 10
soory instead of uem only heat upp 100% ok
Old 10-19-2011, 10:01   #12 (permalink)
Member: 1277146
Thanks Meter: 4
i got one problem of nokia 1200 like "ameho0102" but when i check info it showing 1208 then i changed lcd of 1208 saw that set are working ok......
note that:-- if u attach 1200 lcd with nokia 1209 pcb...in hwk_normal mode it show nokia logo and insertsim..but with battery it shows CONTACT SERVICE ....First determined that either it 1200 or 1208 PCB
Old 08-15-2012, 18:15   #13 (permalink)
Member: 289307
Thanks Meter: 44
just unlock it it works .
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-11-2000 03:43
gsm service provider sidou Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-30-2000 11:09
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.26838 seconds with 10 queries
