Old 07-22-2009, 14:54   #1 (permalink)
Member: 681216
Sonork: 100.1584492
Thanks Meter: 177
1209 contact service
Flash with 5.91 but no luck..........
also unlock & Write good PM but same
Old 07-22-2009, 14:58   #2 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
get SELF TEST through HWK
i think LCD is not competible
attach set and GO on NOraml mode
if set power up normally and on Battery it shows Contact service then ur LCD is not competible
Old 07-22-2009, 15:05   #3 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
normall heat flash and unlcok ........
Old 07-22-2009, 15:11   #4 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,174
..::Brother to first erase and flash downgrade version 4.11 with jaf box and write good pm and unlock so your problem solved:;..
The Following User Says Thank You to RIZWANJAT For This Useful Post:
Old 07-22-2009, 16:09   #5 (permalink)
diabel02's Avatar
Member: 737175
Thanks Meter: 87
clic here...
http://repair-mobiles.com/nokia/
...and post result
::Good Luck::
Old 07-31-2009, 20:48   #6 (permalink)
Member: 681216
Sonork: 100.1584492
Thanks Meter: 177
Every think do it but same
Old 08-01-2009, 03:26   #7 (permalink)
Registered User
Member: 314561
Thanks Meter: 16
change plug in and flash with jaf easy cable
Old 08-01-2009, 03:29   #8 (permalink)
raza ahmad's Avatar
Member: 618615
Thanks Meter: 85
yess use easy flash cable all ok
Old 08-01-2009, 07:14   #9 (permalink)
.::VijayAnand::.'s Avatar
Member: 740523
Thanks Meter: 93
write good pm then unclock u r problem solve........
Old 10-05-2009, 16:13   #10 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
solution is here
enjoy....
http://forum.gsmhosting.com/vbb/show...70#post4906570
WBR
Asif Shahzad
G S M - D O C T O R .. T E A M
1209 contact service gulam khadir Nokia Digital Core Technology 4 ( DCT-4 ) 14 06-14-2014 16:23
1209 contact service dev452005 Nokia Hardware & Hardware Repair 47 11-15-2011 13:10
1209 contact service biniesh_08 Nokia Hardware & Hardware Repair 6 10-05-2009 16:45
nokia 1209 contact service tinkutinku Cyclonebox 10 10-05-2009 16:24
Page generated in 0.17072 seconds with 9 queries
